Problem with the sonic analysis of Plex Media Server on a Nas DS920+ Synology DSM7
Server Version#: 1.32.8.7639
Player Version#: 4.116.1
Hello, I am using Plex Media Server on my Nas DS920+ Synology DSM7 and I am having issues with the sonic analysis features. I have tried restarting the Plex Media server and reinstalling it, but it did not solve the problem. When I scan my library, the sonic analysis does not work anymore. I would like to know if anyone has encountered a similar problem and how it was resolved. Thank you in advance for your help!
PS/ I have an error in logs when I scan my library: [MusicAnalysis] Error decoding analysis input files (exit code: 69)
Plex Media Server Logs_2024-01-12_15-42-23.zip (7.2 MB)
I have a similar issue. From time to time, Plex gets stuck for hours/days on ā€œProcessing 2 albumsā€. Even if I did not add any new album since the last scan.
@tholelosan
Your logs are showing the files FFMPEG cannot decode.
Jan 12, 2024 15:17:46.553 [139717003270968] DEBUG - Subscription: Refreshed all content in 3 ms.
Jan 12, 2024 15:17:48.931 [139717095258936] DEBUG - Jobs: '/volume1/@appstore/PlexMediaServer/Plex Transcoder' exit code for process 5712 is 0 (success)
Jan 12, 2024 15:17:48.931 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex\ Media\ Server/Codecs/90a317c-4653-linux-x86_64/' "/volume1/@appstore/PlexMediaServer/Plex Transcoder" -i "/volume1/Media/Music/Unknown Artist/Unknown Album/01 - Unknown Title.m4a" -ac 1 -ar 16000 -acodec pcm_s16le track-0003.wav
Jan 12, 2024 15:17:48.931 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] In directory: "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/music-analysis-input-c29436af-ead9-402e-8378-e25b00ba6f91"
Jan 12, 2024 15:17:48.933 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Jobs: Starting child process with pid 5947
Jan 12, 2024 15:17:49.136 [139717095258936] DEBUG - Jobs: '/volume1/@appstore/PlexMediaServer/Plex Transcoder' exit code for process 5947 is 69 (failure)
Jan 12, 2024 15:17:49.136 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex\ Media\ Server/Codecs/90a317c-4653-linux-x86_64/' "/volume1/@appstore/PlexMediaServer/Plex Transcoder" -i "/volume1/Media/Music/Unknown Artist/Unknown Album/01 - Unknown Title 1.m4a" -ac 1 -ar 16000 -acodec pcm_s16le track-0004.wav
Jan 12, 2024 15:17:49.136 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] In directory: "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/music-analysis-input-c29436af-ead9-402e-8378-e25b00ba6f91"
Jan 12, 2024 15:17:49.136 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Jobs: Starting child process with pid 5957
Jan 12, 2024 15:17:49.282 [139717095258936] DEBUG - Jobs: '/volume1/@appstore/PlexMediaServer/Plex Transcoder' exit code for process 5957 is 69 (failure)
Jan 12, 2024 15:17:49.283 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex\ Media\ Server/Codecs/90a317c-4653-linux-x86_64/' "/volume1/@appstore/PlexMediaServer/Plex Transcoder" -i "/volume1/Media/Music/Unknown Artist/Unknown Album/01 - Unknown Title 2.m4a" -ac 1 -ar 16000 -acodec pcm_s16le track-0005.wav
Jan 12, 2024 15:17:49.283 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] In directory: "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/music-analysis-input-c29436af-ead9-402e-8378-e25b00ba6f91"
Jan 12, 2024 15:17:49.283 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Jobs: Starting child process with pid 5967
Jan 12, 2024 15:17:50.412 [139717095258936] DEBUG - Jobs: '/volume1/@appstore/PlexMediaServer/Plex Transcoder' exit code for process 5967 is 0 (success)
Jan 12, 2024 15:17:50.412 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex\ Media\ Server/Codecs/90a317c-4653-linux-x86_64/' "/volume1/@appstore/PlexMediaServer/Plex Transcoder" -i "/volume1/Media/Music/Unknown Artist/Unknown Album/01 - Unknown Title 3.m4a" -ac 1 -ar 16000 -acodec pcm_s16le track-0006.wav
Jan 12, 2024 15:17:50.412 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] In directory: "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/music-analysis-input-c29436af-ead9-402e-8378-e25b00ba6f91"
Jan 12, 2024 15:17:50.414 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Jobs: Starting child process with pid 5978
Jan 12, 2024 15:17:50.890 [139717095258936] DEBUG - Jobs: '/volume1/@appstore/PlexMediaServer/Plex Transcoder' exit code for process 5978 is 0 (success)
Jan 12, 2024 15:17:50.890 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex\ Media\ Server/Codecs/90a317c-4653-linux-x86_64/' "/volume1/@appstore/PlexMediaServer/Plex Transcoder" -i "/volume1/Media/Music/Unknown Artist/Unknown Album/01 - Unknown Title 4.m4a" -ac 1 -ar 16000 -acodec pcm_s16le track-0007.wav
Jan 12, 2024 15:17:50.890 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] In directory: "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/music-analysis-input-c29436af-ead9-402e-8378-e25b00ba6f91"
Jan 12, 2024 15:17:50.890 [139717033298744] DEBUG - [MusicAnalysis/JobRunner] Jobs: Starting child process with pid 5989
Jan 12, 2024 15:17:53.356 [139716969720632] DEBUG - Request: [192.168.1.84:57620 (Subnet)] GET /library/sections (4 live) #7d49 GZIP Signed-in Token (tholelosan) (Safari)
If you look, it’s trying to break it out into 5 tracks.
Thank you @ChuckPa , I fixed that.
But it seems that it doesn’t solve the problem. Sonic analysis still doesn’t work.
Plex Media Server Logs_2024-01-12_19-25-25.zip (6.8 MB)
After verification, it would seem that the analysis worked on some albums in my library, but not on a large majority of them. The sonic features of plexamp are still unusable.
Thanks for your help.
After having searched the last posts of the forum, I understood that I’m not the only one having issues with this.
I’ve not found any solution.
My database isn’t corrupted.
I’ve tried a few leads read on different posts, for example, deleting the too long tracks. The analysis happened on 20 additional albums, it seems, which I couldn’t identify, but it’s impossible for me to pinpoint where it gets stuck. Some artists and albums are sonically similar, however, it’s impossible to launch Sonic Adventure on Plexamp. In the console, no error messages during a scan, however, the same warning message appears ā€œ[MusicAnalysis] No analysis blob foundā€ for several items.
I continue my research. But please, if a Plex technician can tell me what’s going on and can help me resolve this topic, I would greatly appreciate it.
Plex Media Server Logs_2024-01-15_14-36-42.zip (5.8 MB)
I noticed that some artists are no longer accessible: they appear when I type their name in the search bar, and their albums are viewable. But when I click on the artists in question, ā€˜something went wrong, An unexpected error occurred.’
Is this related?
Today, Plex’s analysis remains stuck on ā€˜Finding Albums’, and I can’t use the player on Mac, it’s constantly buffering. I have to go through the web player.
Plex Media Server Logs_2024-01-17_13-02-46.zip (7.0 MB)
