Problems creating new libraries
Server Version#:1-41-1-9057- af5eaea7a
The existing libraries work well (update after scanning). But I cannot add new libraries or change the folderof existing libraries. when I click on the + to add a new library, the window opens and I can select a type but I cannot click to “add folder” or the extended option (both greyed out)
Stop and restart your server.
Use the hosted web app, not the local one.
Use a standard web browser, not one that has been constructed to disable and block parts of websites.
Disable web browser add-ons which do the same in standard browsers.
All done, no success.
Is it correct that, following the link to the hosted web app, I end up here https://app.plex.tv/desktop/#!/ ?
Yes, that is expected.
Can you enable debug logging in the server?
If you can, do it. Then stop and restart Plex server.
Wait ~3 minutes. Then fetch the server logs.
This exact issue has been in the TrueNAS Core (FreeBSD) version since 1.40.0 I am currently still using 1.32.8 which is still working fine.
