Problems using PulseAudio PlexAmpHeadless
When I set PulseAudio as output it is not working, it is working though if I select my USB DAC directly. But I need to use PulseAudio to do some audio processing (Compressor/limiter). See logging:
It would be great if using PulseAudio with PlexAmpHeadless would work, can it?
you might try running plexamp from a systemd --user service (i think pulseaudio also runs this way)
Thanks a lot tgp-2 That works a treat!
