Problems with audio bluetooth for EAC3
EDIT: i found a strange solution for this bug.
  • with headphones paired, but not active
  • first of all, click ON on Dolby processing in advanced options audio
  • second, set the audio output in automatic, and ALL codecs in automatic too
  • activate dolby processing
  • play a file with EAC3 listening in the normal audio environment (soundbar, TV speakers or HomeCinema).
  • then click on the shield menu button, and link audio to media (the headphones)
  • then ALL works normally
Then, the thing is: previously paired headphones but not active / all audio and codecs in AUTO / dolby processing ON / play normally in speakers / click menu BT device and link audio to media
Hello again, good morning:
I have a problem when listening to files with EAC3 audio using bluetooth headphones (i’ve tried several), the file tries to load, does nothing, until it gives a playback error.
However, without bluetooth, everything is heard normally and in direct play.
I’m using a new Sony 720N headphones (works perfectly using the phone app). And my main player is a nvidia Shield 2019 pro.
thanks for reading
Server Version#: 1.32.1.6999
Player Version#: 9.23.0
