Here’s what I think is the relevant section of the log file
04-21 07:34:53.561 i: [FFmpeg] [INFO] [hls @ 0xb42f1400] Opening 'https://192-168-1-34.91039e1f9ebe40ed851bfb93ab971b53.plex.direct:32400/video/:/transcode/universal/session/27cf9f1a4f9197d3-com-plexapp-android/base/00159.ts' for reading
04-21 07:34:53.600 i: [MediaCodecVideoSyncRenderer] Decoder initialised, after 0 attempts.
04-21 07:34:53.600 i: [ExoPlayer][EventLogger] videoDecoderInitialized [eventTime=1.97, mediaPos=1599.51, window=0, period=0, OMX.amlogic.avc.decoder.awesome2]
04-21 07:34:53.601 i: [ExoPlayer][EventLogger] videoInputFormat [eventTime=1.98, mediaPos=1599.51, window=0, period=0, id=0, mimeType=video/avc, bitrate=8607000, codecs=h264, res=1920x1080, fps=23.976025]
04-21 07:34:53.608 i: [ExoPlayer][EventLogger] audioInputFormat [eventTime=1.98, mediaPos=1599.51, window=0, period=0, id=1, mimeType=audio/ac3, bitrate=8607000, codecs=ac3, channels=6, sample_rate=48000, language=english, selectionFlags=[default,forced]]
04-21 07:34:53.608 i: [TranscodeSession] Updating session status
04-21 07:34:53.610 i: Fetching [method:GET] https://192.168.1.34:32400/transcode/sessions/27cf9f1a4f9197d3-com-plexapp-android?X-Plex-Token=...qtD3&X-Plex-Language=en-us
04-21 07:34:53.625 i: [TranscodeSession] Resolution: -1x-1, Video: Remux, Audio: Transcode, Speed: 34.500000, Throttled: false
04-21 07:34:54.129 i: [ThemeMusic] Fade out complete. Stopping media player.
04-21 07:34:54.572 i: [FFmpeg] [INFO] [hls @ 0xb42f1400] Opening 'https://192-168-1-34.91039e1f9ebe40ed851bfb93ab971b53.plex.direct:32400/video/:/transcode/universal/session/27cf9f1a4f9197d3-com-plexapp-android/base/00160.ts' for reading
04-21 07:34:55.726 i: [FFmpeg] [INFO] [https @ 0xadc1f800] Opening 'https://192-168-1-34.91039e1f9ebe40ed851bfb93ab971b53.plex.direct:32400/video/:/transcode/universal/session/27cf9f1a4f9197d3-com-plexapp-android/base/00161.ts' for reading
04-21 07:34:55.955 i: [ExoPlayer][EventLogger] videoDisabled [eventTime=4.33, mediaPos=1599.51, window=0, period=0]
04-21 07:34:55.956 i: [ExoPlayer][EventLogger] audioDisabled [eventTime=4.34, mediaPos=1599.51, window=0, period=0]
04-21 07:34:56.007 i: [FF][MediaPeriod] Releasing.
04-21 07:34:56.007 i: [FF] Loading canceled (released: true)
04-21 07:34:56.008 i: [FFmpeg] [INFO] Demuxer has been successfully interupted.
04-21 07:34:56.010 i: [FF] Releasing demuxer.
04-21 07:34:56.011 i: [FFmpeg] [INFO] Demuxer closing.
04-21 07:34:56.017 e: [ExoPlayer][EventLogger] playerFailed [eventTime=4.39, mediaPos=1599.51, window=0, period=0, errorCode=ERROR_CODE_AUDIO_TRACK_INIT_FAILED
com.google.android.exoplayer2.o: MediaCodecAudioRenderer error, index=3, format=Format(1, null, null, audio/ac3, ac3, 8607000, english, [-1, -1, -1.0], [6, 48000]), format_supported=YES
at com.google.android.exoplayer2.r1.handleMessage(SourceFile:43)
at android.os.Handler.dispatchMessage(Handler.java:103)
at android.os.Looper.loop(Looper.java:214)
at android.os.HandlerThread.run(HandlerThread.java:67)
Caused by: com.google.android.exoplayer2.audio.t$b: AudioTrack init failed 0 Config(48000, 252, 39998)
at com.google.android.exoplayer2.audio.b0$f.b(SourceFile:7)
at com.google.android.exoplayer2.audio.b0.F(SourceFile:1)
at com.google.android.exoplayer2.audio.b0.G(SourceFile:1)
at com.google.android.exoplayer2.audio.b0.V(SourceFile:2)
at com.google.android.exoplayer2.audio.b0.f(SourceFile:16)
at com.google.android.exoplayer2.audio.g0.Y(SourceFile:7)
at r2.o.b(SourceFile:8)
at r2.o.render(SourceFile:11)
at com.google.android.exoplayer2.r1.q(SourceFile:14)
at com.google.android.exoplayer2.r1.handleMessage(SourceFile:25)
... 3 more
Suppressed: com.google.android.exoplayer2.audio.t$b: AudioTrack init failed 0 Config(48000, 252, 39998)
... 13 more
Caused by: java.lang.UnsupportedOperationException: Cannot create AudioTrack
at android.media.AudioTrack$Builder.build(AudioTrack.java:1018)
at com.google.android.exoplayer2.audio.b0$f.g(SourceFile:11)
at com.google.android.exoplayer2.audio.b0$f.e(SourceFile:2)
at com.google.android.exoplayer2.audio.b0$f.b(SourceFile:1)
... 12 more
... 12 more
04-21 07:34:56.018 e: [Player][ExoPlayer] Playback error detected
04-21 07:34:56.021 i: [FFmpeg] [INFO] Demuxer has been interupted...
04-21 07:34:56.022 i: [FFmpeg] [INFO] Demuxer has been closed, interrupting FFmpeg...
04-21 07:34:56.022 e: An exception occurred: com.google.android.exoplayer2.o: MediaCodecAudioRenderer error, index=3, format=Format(1, null, null, audio/ac3, ac3, 8607000, english, [-1, -1, -1.0], [6, 48000]), format_supported=YES
04-21 07:34:56.023 i: [Player][Timeline] Handling player error
04-21 07:34:56.023 i: [Player][Timeline] Playback stopped (error: true)
04-21 07:34:56.024 e: Stacktrace: com.google.android.exoplayer2.o: MediaCodecAudioRenderer error, index=3, format=Format(1, null, null, audio/ac3, ac3, 8607000, english, [-1, -1, -1.0], [6, 48000]), format_supported=YES
... 3 more
... 13 more
... 12 more
... 12 more
04-21 07:34:56.025 i: [Player][Timeline] Player error not known by server, reporting original player error (or a playback interrupted one)
04-21 07:34:56.025 i: [Player] Error reported: UnknownError (null)
04-21 07:34:56.026 i: [Player][Timeline] Playback stopped (error: false)
04-21 07:34:56.031 i: [FFmpeg] [INFO] Demuxer has been interupted...
04-21 07:34:56.032 i: [FFmpeg] [INFO] Demuxer has been closed, interrupting FFmpeg...
04-21 07:34:56.043 i: [TranscodeSession] Stopping...
04-21 07:34:56.045 i: [FFmpeg] [INFO] Demuxer has been interupted...
04-21 07:34:56.045 i: [Player][Error] Displaying player error...
04-21 07:34:56.046 i: [DialogBehaviour] Showing dialog.
04-21 07:34:56.048 i: [FFmpeg] [INFO] Demuxer has been closed, interrupting FFmpeg...
04-21 07:34:56.048 i: [ExoPlayer][EventLogger] state [eventTime=4.43, mediaPos=1599.51, window=0, period=0, IDLE]
04-21 07:34:56.055 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
04-21 07:34:56.056 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 384
04-21 07:34:56.057 i: [BufferHelper] Segment count: 2457
04-21 07:34:56.061 i: [TranscodeSession] Notifying server that we've stopped
04-21 07:34:56.062 i: Fetching [method:GET] https://192.168.1.34:32400/video/:/transcode/universal/stop?autoAdjustQuality=1&hasMDE=1&location=lan&mediaBufferSize=157248&path=%2Flibrary%2Fmetadata%2F113560&session=27cf9f1a4f9197d3-com-plexapp-android&X-Plex-Client-Identifier=27cf9f1a4f9197d3-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Device=Chromecast&X-Plex-Platform=Android&X-Plex-Platform-Version=10&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Version=9.0.6.31998&X-Plex-Token=...qtD3&X-Plex-Language=en-us
04-21 07:34:56.063 i: [FFmpeg] [INFO] [Cache] Close requested, terminating.
04-21 07:34:56.064 i: [FFmpeg] [INFO] [Cache] Cache has been closed, interrupting AVIO ...
04-21 07:34:56.075 i: [FFmpeg] [INFO] [Cache] Close requested, terminating.
04-21 07:34:56.076 i: [FFmpeg] [INFO] Demuxer pipeline terminated.
04-21 07:34:56.077 i: [FFmpeg] [INFO] Demuxer has been successfully closed.
04-21 07:34:58.641 i: [EngineEventManager] onPlaybackStopped: Closed
04-21 07:34:58.642 i: [Player][Timeline] Playback stopped (error: false)
04-21 07:34:58.642 i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
04-21 07:34:58.643 i: [PlaybackTimeBehaviour] Time: 0 IsStarted: false
04-21 07:34:58.643 i: [TranscodeSession] Stopping...
04-21 07:34:58.644 i: [PlayQueueProgressBehaviour] Updating PlayQueueManager state, isPlaying: false
04-21 07:34:58.645 i: [SleepTimerBehaviour] Sleep timer behaviour changed.
04-21 07:34:58.646 i: [WiFiLockBehaviour] Releasing WiFi lock since playback was stopped.
04-21 07:34:58.646 i: [DisplayBehaviour] Cancelling stop playback runnable to prevent unexpected stop.
04-21 07:34:58.650 i: [MediaSessionBehaviour] Updating state to STOPPED
04-21 07:34:58.654 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
04-21 07:34:58.655 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 384
04-21 07:34:58.656 i: [BufferHelper] Segment count: 2457
04-21 07:34:58.657 i: [MemoryOptimisationBehaviour] Expanding memory cache.
04-21 07:34:58.658 i: [TranscodeSession] Notifying server that we've stopped
04-21 07:34:58.659 i: [VideoAwakeBehaviour] Keep screen awake has been requested disabled for VideoAwakeBehaviour.
04-21 07:34:58.661 i: [AudioFocusBehaviour] Behaviour being destroyed, giving up audio focus
04-21 07:34:58.662 i: Fetching [method:GET] https://192.168.1.34:32400/video/:/transcode/universal/stop?autoAdjustQuality=1&hasMDE=1&location=lan&mediaBufferSize=157248&path=%2Flibrary%2Fmetadata%2F113560&session=27cf9f1a4f9197d3-com-plexapp-android&X-Plex-Client-Identifier=27cf9f1a4f9197d3-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Device=Chromecast&X-Plex-Platform=Android&X-Plex-Platform-Version=10&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Version=9.0.6.31998&X-Plex-Token=...qtD3&X-Plex-Language=en-us
04-21 07:34:58.672 i: [HomeHubs] Item content source server://ea56c5c54c05c89d04eb4390de6df9f2b50915bb/com.plexapp.plugins.library has volatile hubs: marking as stale.
04-21 07:34:58.676 i: [DisplayBehaviour] Cancelling stop playback runnable to prevent unexpected stop.
04-21 07:34:58.677 i: [UpdateChannelsBehaviour] app in foreground, scheduling a pending update Item was updated or removed
04-21 07:34:58.678 i: [PreplayViewModel] Refreshing metadata for Season 1
04-21 07:34:58.681 i: [HomeHubsManager] Discovering. Force: false. Partial: false. Reason: volatile hub updated
04-21 07:34:58.687 e: Error fetching https://192.168.1.34:32400/video/:/transcode/universal/stop?autoAdjustQuality=1&hasMDE=1&location=lan&mediaBufferSize=157248&path=%2Flibrary%2Fmetadata%2F113560&session=27cf9f1a4f9197d3-com-plexapp-android&X-Plex-Client-Identifier=27cf9f1a4f9197d3-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Device=Chromecast&X-Plex-Platform=Android&X-Plex-Platform-Version=10&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Version=9.0.6.31998&X-Plex-Token=...tml>
04-21 07:34:58.688 i: [MergingHubManager] Notifying listeners with status: SUCCESS
04-21 07:34:58.700 i: [MediaSessionBehaviour] Releasing MediaSessionHelper
04-21 07:34:58.704 i: [MediaSessionHelper] Releasing media session with tag: video
04-21 07:34:58.706 i: [DisplayBehaviour] Reverting back to the original display mode.
04-21 07:34:58.710 i: [DisplayBehaviour] Mode is already set to our best mode of 1920x1080 @ 59.9401Hz (1).
04-21 07:34:58.712 i: [DynamicHome] Reusing results from previous discovery.
04-21 07:34:58.718 i: [DynamicHome] Starting new discovery task because there are stale content sources.
04-21 07:34:58.736 i: Fetching [method:GET] https://192.168.1.34:32400/hubs/continueWatching?contentDirectoryID=1%2C3%2C2&includeDetails=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&X-Plex-Token=...qtD3&X-Plex-Language=en-us
04-21 07:34:58.745 i: [MediaSessionBehaviour] Releasing MediaSessionHelper
04-21 07:34:58.774 i: [ThemeMusic] Playing new theme music.
04-21 07:34:58.796 i: Resuming HomeActivity.
