Don’t know if anybody can help here, but I have recently used Mp3tag to tag .wav cd rips. When scanning my music library the song titles of all the non-recognised albums (such as live recordings and vinyl rips) have disappeared. I’ve tried changing the settings of the library to prefer local metadata but still no track titles. The album art, artist, track number and year all work fine but not the titles. Can anybody help with this?
I had the same problem, which was solved using “last.fm agent” instead of “plex music agent”, do some testing and you will see.
You need to FOLLOW these steps:
- Go to the advanced settings of your music library
- Select the LAST.FM agent
Note 1. All your songs must have the album title.
Note 2. If you only have two or more songs from the same album, you must put the track number in each song.
Done.
You will see your library the way you want it!
I hope you find it useful
That didn’t work for me. I’ve made sure that the tags are all right and refreshed the metadata with Last.fm. I’ve also made sure that the track title field is not locked. It’s just the way it was before.
Have you tried using “plex music scanner”?
I’ve also given that a go.
Plex cannot read meta tags from wav files.
If you need lossless quality, use the Flac format.
If it can’t read the metadata tags, can you suggest an easy way to batch convert my files losslessly from .wav to .flac?
Flac is always losslessly.
You can use whatever works for you.
Many audio players have conversion already built in. e.g. foobar2000
Or you use the official flac packer https://www.rarewares.org/lossless.php
I recommend mp3tag which you then can use to copy & paste the metatags from the wav to the flac versions.
mp3tag has the also useful feature to derive metatags from folder names and parts of the filename. Saves a lot of manual work.
Thanks. Ill give that a go. I’m already familiar with mp3tag because it’s what I used originally to tag them through the discogs database. I’ll have a look at the official flac packer and update you on if it worked.
foobar2000 is probably better at retaining the metatags from wav
