Problems with multipart naming of miniseries
Server Version#: 1.42.1.10060
Lonesome Dove is a 4 part miniseries that has been ripped from disks. I have all four in a folder \Lonesome Dove (1989)
The are named as follows:
Lonesome Dove (1989) -part1.mkv
Lonesome Dove (1989) - part2.mkv
Lonesome Dove (1989) - part3.mkv
Lonesome Dove (1989) - part4.mkv
I would like to be able to watch the episodes separately. Currently Plex is defaulting to “Lonesome Dove: The Making of an Epic” which is the documentary from 1970 but it does list 6hr 11min to watch so it is recognizing the four parts. I have tried the “Fix Match” but it doesn’t bring up the correct option.
I have tried different naming conventions as per Plex documentation but have not been able to get anything to work. Thank you in advance for your help!
For mini-series, use TV show naming and add to a TV show library.
You may need to Plex Dance the files after renaming/re-organizing.
/tv
  /Lonesome Dove (1989)
    /Season 01
      /Lonesome Dove (1989) s01e01.mkv
      /Lonesome Dove (1989) s01e02.mkv
      /Lonesome Dove (1989) s01e03.mkv
      /Lonesome Dove (1989) s01e04.mkv
Thank you for your help. I wondered about doing that, but hadn’t put it in TV. Had left it in the Movies folder
One final question - I think. Can subtitle files be added then to play with these files?
I did find the answer in the documentation. Again, thank you.
