Problems with new Plex android app
New Plex update (May 2025)
Samsung A54
Android 14
  1. In-file ASS subtitles in mkv files don’t work. Changing video quality has no effect on if subtitles display.
  2. Playing video sub menu “Playback Options” does nothing and freezes the menu so you have to exit the video and play it again.
Hello
Lots of problems too on my samsung S20FE, impossible to cast via google cast the multicanal soundtrack
Very slow interface…
Some icon doesn’t appear propely…
Most of us have downgraded to a usable version.
Same problem with the Android Client
About a week ago both my Android tablets were updated to 2025.14.0, then a few days ago to 2025.15.0. But no change.
One tablet shows the Plex Media Server is offline (it does have the correct name).
Client version: 2025.15.0; Platform version 7.
The other tablet doesn’t show any art. Just the name beneath the entry. If I click on an entry I do get the art for it, but no pictures for cast, just their names. I does play w/o a problem.
Client version: 2025.15.0; Platform version 9.
I too have downgraded (thanks for the instructions)
Plex Media Server: Ubuntu 24.04.2 LTS; Plexmediaserver_1.41.6.9685-d301f511a_amd64
When can I reasonably expect this to be fixed?
I downgraded mine to client version 10.26. Just too many issues with .mkv files, h265 / HEVC, Chromecast, etc., with the “new version”. Good luck…
I have exactly the same issue!
Google Pixel 7A
Android 15 Security update March 5, 2025 Kernel 6.1.99-android14-11
Plex app 2025.15.0
Confirm issue 2 in OP, “Playback Options” immediately closes menu and app is no longer responsive to touch (until exiting and re-opening app). Almost as if the playback options screen is completely transparent and covering the screen, but not responding to touch.
Reproducible: yes
Edit: I swiped (go home gesture in Android) to the Home screen, then swiped back (recents gesture) to the Plex app, and I saw the Playback Options screen and could make a selection. However, this behavior is not easily reproducible. About once in every 5-6 tries will I actually see the Playback Options screen when going to the Home screen and back to the Plex app via the recent app menu in Android.
Edit 2: I was able to change the aspect ratio to “stretch”, and now when I try to access Playback Options, I see a black bar across the bottom (not all the way across), almost as if the Playback Options window is shifted down below most of the screen.
Confirmed: I switched to 3 button navigation (instead of swipe navigation), then I was able to drag the black bar from the bottom of the screen. It was indeed the Playback Options window. Something is causing that Playback Options window to be rendered too far down.
Samsung galaxy s22 ultra
Some of my 480p content will not play in the correct aspect ratio with updated app works fine when I role back to older version.
Same issue 2 months later and no acknowledgement from devs, apparently.
