2025.14.0 no longer plays remotely
Server Version#:lastest
Player Version#:2025.14.0 on Android 14
Home page loads just fine when local or remote but unable to play any videos while remote through relay.
If I roll back to an older version of Plex it works fine. Error says (source error) seems to be isolated to just this version of player on android and working on other platforms just fine.
Yes, I have the same issue after the update on the android app
Same. Can’t play any videos on android since the latest update
Same problem here since updating my Android mobile devices, still working fine on my firesticks & shield.
Update: 2025.15.0 was released, still not working. Rolling back to an older version fixed it but can’t update if I want to stream remotely on Android
Same problem for me after last mobile android update. :frowning:
This has been fixed in 2025.16.0, which should be available next week. You can sideload the APK below to try it sooner;
https://artifacts.plex.tv/react-builds/2025.16.0.966828397-4fa82/PlexReactNative-2025.16.0.966828397-4fa82.apk
Update 2025.16.0 fixed this issue for me, thank you.
