Progress Indication Stops @ 50%
Server Version#: 1.20.3.3421
Player Version#: 8.7.2…20952
Found a bug… I have a Samsung 10 Plus (Android version 10). After PLEX Sever finishes converting a video from my server; my Samsung immediately starts the download process. The problem is, the download stays at 50% until it’s done. In other words, PLEX doesn’t display the actual download progress. Leaving the user to think the download is stuck, or a re-download/reinstall is necessary.
Not a bug. The app doesn’t actually track the total length of all objects to be downloaded so it doesn’t calculate the percentage as you think. It tracks based on the number of files. So if you are only syncing 1 file, it will stick at 50% until that 1 file is done. If there are 2 files, it will update to 75% after the first file is done, etc.
Oh… Thanks!!!
