1 - Stop Plex Server on original QNAP
2- Used RSync to move the media files.
3 - Installed Plex on New NAS.
4 - Stopped Plex on new NAS
5 - Copied the Libraries folder over from CACHEDEV1_DATA/.qpkg/PlexMediaServer on old to new NAS
6 - Started Plex
7 - Plex requested a Server name so I gave it a new one.
8 - No Libraries showing.
I can manually add them but I would like to retain all of my Metadata eg matches, collections I’ve made or deleted and what I’ve watched and not watched.
Can you point me in the direction of what I might have missed as I’m guessing I’m missing something obvious.
I saw the missing files when Plex was installed and the directory was automatically created during the install I’ve just created a share to the directory so you can see the files.
Do I just need to copy them over or just delete the entire directory and start again. As I have the share available I could over write the entire directory.
I have fixed the problem it seems the Plex server that you can install from the QNAP Applications page does not install correctly and misses a lot of files eg the Binaries.
I have downloaded version 1.18 and installed that manually. Once this was done I recopied the library directory and it all works.
