I filtered mine out (I have a ton of shares)
drwxrwxrwx 40 admin administrators 4096 2019-09-02 02:58 CACHEDEV1_DATA/
drwxrwxrwx 90 admin administrators 4096 2019-10-03 16:52 CACHEDEV2_DATA/
drwxrwxrwx 7 admin administrators 4096 2019-08-05 17:28 CACHEDEV3_DATA/
drwxrwxrwx 13 admin administrators 4096 2019-09-16 17:00 CACHEDEV4_DATA/
drwxrwxrwx 3 admin administrators 4096 2019-09-16 23:11 CACHEDEV5_DATA/
drwxrwxrwx 2 admin administrators 40 2005-09-18 23:32 HDA_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDB_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDC_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDD_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDE_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDF_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDG_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDH_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDI_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDJ_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDK_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDL_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDM_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDN_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDO_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDP_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:41 HDQ_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:42 HDR_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:42 HDS_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:42 HDT_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:42 HDU_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:42 HDV_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:42 HDW_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:42 HDX_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:42 HDY_DATA/
drwxrwxrwx 2 admin administrators 40 2005-12-07 06:42 HDZ_DATA/
When you moved things around, did you reset it to factory?
I ask because initially, my HDD array was CACHEDEV1.
In order to move it to the M.2 SSDs, I need to pull all the drives and factory reset it.
When I then installed QTS, it rooted itself on the M.2’s
Inserting the HDDs automatically assigned them as CACHEDEV2
You might need to to the same basic procedure to get your devices renumbered
-or-
teamviewer session with QNAP support while they dismount the pools and reassociate them with lv’s . Those logical volumes are what lvm_init look for when mapping to CACHEDEV_DATA
This is what lvm_init accomplishes at boot time.
[/dev] # mount | grep cache
/dev/mapper/cachedev1 on /share/CACHEDEV1_DATA type ext4 (rw,usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,data_err=abort,nodelalloc,nopriv,nodiscard,noacl)
/dev/mapper/cachedev2 on /share/CACHEDEV2_DATA type ext4 (rw,usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,data_err=abort,nodelalloc,nopriv,nodiscard,noacl)
/dev/mapper/cachedev3 on /share/CACHEDEV3_DATA type ext4 (rw,usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,data_err=abort,nodelalloc,nopriv,nodiscard,noacl)
/dev/mapper/cachedev4 on /share/CACHEDEV4_DATA type ext4 (rw,usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,data_err=abort,nodelalloc,nopriv,nodiscard,noacl)
/dev/mapper/cachedev5 on /share/CACHEDEV5_DATA type ext4 (rw,usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,data_err=abort,nodelalloc,nopriv,nodiscard,noacl)
[/dev] #
The support guys can change which pool gets assigned to which /dev/mapper device entry.
