Hi
Since I have installed Plex on my QNAP TS-563, each day plex is stop working on 16.30 o clock. After this, I must stop Plex and start it again. After this it works for next day.
I hope you can help me.
QNAP don’t show me a log at this time.
Hi
You could look at the Plex Logs (Settings > Server > Help > Download Logs).
As it’s such a stable pattern… is there anything changing around that time? – e.g. your router assigning new IP addresses every day
What are the actual symptoms of your Plex going down? Can you no longer access the server remotely / in your network, via a client / on that machine itself through Plex Web…?
Hi
Here you have two logs: The first are from 20 april, and the second from today after restart
No. Nothing. I have a second server for an other subnet and this work (Synology nas)
My audiobook is stop playback. I can’t connect from ios three different IOS Device
After stop and start, all works
Here you find the second log
If I may jump in?
It starts locking up here. notice the 401 http return code (Forbidden).
Apr 20, 2018 16:35:43.586 [0x7fe778bff700] DEBUG - HTTP 200 response from GET https://plex.tv/servers/c3180754504fccf761a83d107638b860b9cb8be5/access_tokens.xml?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1&unknownToken=xxxxxxxxxxxxxxxxxxxx
Apr 20, 2018 16:35:43.609 [0x7fe778bff700] DEBUG - MyPlex: updating with 111 access tokens
Apr 20, 2018 16:35:43.612 [0x7fe778bff700] DEBUG - Auth: authenticating user as guest
Apr 20, 2018 16:35:43.612 [0x7fe778bff700] DEBUG - Request: [1XX.1XX.2XX.158:42026 (WAN)] GET /:/timeline?bufferedTime=0&duration=293928&key=%2Flibrary%2Fmetadata%2F65342&location=cellular&playQueueItemID=1024&ratingKey=65342&state=paused&time=0 (3 live) TLS GZIP Signed-in Token ()
Apr 20, 2018 16:35:43.614 [0x7fe778bff700] DEBUG - Completed: [1XX.1XX.2XX.158:42026] 401 GET /:/timeline?bufferedTime=0&duration=293928&key=%2Flibrary%2Fmetadata%2F65342&location=cellular&playQueueItemID=1024&ratingKey=65342&state=paused&time=0 (3 live) TLS GZIP 0ms 338 bytes
Apr 20, 2018 16:36:08.346 [0x7fe76d447700] DEBUG - Sync: uploadStatus
Apr 20, 2018 16:36:16.664 [0x7fe76d447700] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Apr 20, 2018 16:36:16.665 [0x7fe7713ff700] DEBUG - PublicAddressManager: Obtaining public IP.
Apr 20, 2018 16:36:16.665 [0x7fe7713ff700] DEBUG - HTTP requesting GET http://plex.tv/pms/:/ip
Apr 20, 2018 16:36:16.773 [0x7fe7713ff700] DEBUG - HTTP 200 response from GET http://plex.tv/pms/:/ip
Apr 20, 2018 16:36:16.773 [0x7fe7713ff700] DEBUG - PublicAddressManager: Got public IP from http://plex.tv: 2XX.1X.1XX.7X
Apr 20, 2018 16:36:28.784 [0x7fe7713ff700] DEBUG - NAT: UPnP, getPublicIP didn't find usable IGD.
Apr 20, 2018 16:36:38.787 [0x7fe7713ff700] WARN - NAT: PMP, timed out waiting for response.
Apr 20, 2018 16:36:38.788 [0x7fe7713ff700] DEBUG - MyPlex: Last published value didn't change, we're done.
Apr 20, 2018 16:46:41.099 [0x7fe778bff700] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Apr 20, 2018 16:46:41.099 [0x7fe778bff700] DEBUG - HTTP requesting GET https://plex.tv/servers/c3180754504fccf761a83d107638b860b9cb8be5/access_tokens.xml?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1&unknownToken=xxxxxxxxxxxxxxxxxxxx
Apr 20, 2018 16:46:41.397 [0x7fe778bff700] DEBUG - HTTP 200 response from GET https://plex.tv/servers/c3180754504fccf761a83d107638b860b9cb8be5/access_tokens.xml?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1&unknownToken=xxxxxxxxxxxxxxxxxxxx
Apr 20, 2018 16:46:41.473 [0x7fe778bff700] DEBUG - MyPlex: updating with 111 access tokens
Apr 20, 2018 16:46:41.476 [0x7fe778bff700] DEBUG - Auth: authenticating user as guest
Apr 20, 2018 16:46:41.476 [0x7fe778bff700] DEBUG - Request: [17X.XX.2XX.1:17884 (WAN)] GET / (5 live) GZIP Signed-in Token ()
Something is clearly hitting it around 16:30. It might be the WAN DHCP address refresh disturbing it because at 16:36 PMS detects the change and goes for a new Public IP update. Yes, kinda out there but i’ve seen crazier.
If you have 1.12.2 available, I suggest installing on top of the existing 1.12.3 (preserves your library) and making a comparative test.
Only other thing I could think of is if this is a shared Internet feed, is someone getting online around that time (kids getting home from school, etc.) and hitting something like an Xbox, etc.?
I have installed the newest Version. And at this time, no other user are connected to the network (only 2 for Plex), and on this Time tv, consoles or so don’t have connection to network, and no backup or nas processe or so is working at this time.
Do you think the firewall is missconfigurated? I have only allowed 32400 TCP
ok. Its not a firewall problem. On a synology NAS it works, on a other QNAP it works. I think the Problem is Plex with QNAP TS-563. All other connections on the QNAP TS-563 is working without any problem
I just had to roll back from QTS 4.3.4.0551 to 4.3.4.0435
What version are you using and at what version did this problem start?
4.3.4.0551 on both qnap. So I will test for two Days if I has the problem on both QNAP. Is your problem solved with downgrade?
It‘s correct. The first NAS had a older Version, But Inhave updated.
My issue was resolved by downgrading to 4.3.4.0435 (previous version).
After downgrading and moving 30+ TB of data later, no errors have been reported
I have completed a full write-up for QNAP and submitted it with the ticket.
Today I had the Problem again. So I had downgraded.
Why you have moving 30+ TB of data? After a Downgrade, a NAS don’t lost the settings and Data
Why you take 4.3.4.0435 and not 4.3.4.0516?
Great. Thank you. Has QNAP send a feedback?
After downgrading and moving 30+ TB of data later, no errors have been reportedI have completed a full write-up for QNAP and submitted it with the ticket.
@ChuckPA is there any update on this QNAP ticket? I’m seeing this as well.
