QNAP - Plex Server starts then drops out after 30 odd secs
Server Version#:1.23.4
Player Version#:Any Really
I just updated my NAS to the latest firmware h4 5.4.2138 once I restarted plex starts and then works for a short while then drops out and the web shops - ERR_CONNECTION_REFUSED
Any advice would be greatly appreciated thanks
Regards
R
Start by restarting your QNAP completely, and if you upgraded from QTS 4.2, you’ll need to upgrade your PMS
If not, and still not working after a restart, we’ll need PMS Logs
Thanks you very much for the quick replay.
I have restarted the QNAP and i updated to the latest firm which is h4.5.4.2138 so a little higher that 4.2. I am on the highest version of the Plex app from the store. I am not sure if I upgrade any higher unless there is way I don’t know about.
How could I get you the log files for? Is there guide for that at all?
Regards
R
Either the link I provided, or use the PlexData share
So looked at the guide and I thought I would chance trying the web GUI way as I have about 30 seconds before I drops.
Lucky for us it worked! Do you need all the zip file or some parts of it?
Regards
R
zip file please
Plex Media Server Logs_2022-09-02_22-06-08.zip (913.3 KB)
Here you go.
Thanks again for your help with this its appreciated greatly
Regards
From your log
Sep 02, 2022 22:05:42.197 [0x7fc56d199b38] ERROR - Failed to begin transaction (../Plugins/PluginDatabaseState.cpp:189) (tries=1): Cannot begin transaction. database is locked
So did you really restart your QNAP ?
Yeah twice now. I am going to shut it down this time and then manually turn it back on just in case this time. But I have selected restarted more them once.
I will let you know as soon as it back up
After that Shutdown / Start i am still getting the same issue
I reinstalled the plex server and it crashes out after 30 still so at this stage i am not sure how to get it working.
Is there any other logs your might want to see?
Regards
R
Are you running any AntiVira solution on your QNAP ?
If so, try and disable for a short test, and then restart QNAP
