Quite a while ago, when I first got my Synology 720+ plex transcoding was not working correctly. I followed someone’s guide to get transcoding working properly at the time. It disabled some driver that was broken at the time.
Here’s the guide I followed…
- Install Synology Text Editor app
- Stop PMS
- Open the Plex share in File Station
- Navigate to Library / Application Support / Plex Media Server
- Right-click Preferences.xml -> Open in Text Editor
- Scroll to the end of the last line (you’ll see a
/>) - In front of that type:
VaapiDriver="i965" - It will look like
VaapiDriver="i965" />(space in front of Vaapi too) - Save the file.
- Start PMS
Does this driver work correctly now? Should I re-enable it? Will I see better performance ‘if’ it has been fixed?
Server Version#: 1.21.0.3616
Player Version#:current
