Question about the supported tuner list
Server Version#: 1.25.5.5492 (Windows 10)
Player Version#: n/a
Tuner Make/Model: Hauppauge 1682 (WinTV-quadHD USB)
Guide/Lineup name: n/a
Using XMLTV?: unknown
Channel number/Name: n/a
On the official supported tuner list (Supported DVR Tuners and Antennas | Plex Support), you show the Hauppauge WinTV-QuadHD on the list, my question is this, does that include the USB version of that unit (WinTV-quadHD USB)?
I was just told they are the same hardware and the USB version is supported too.
Awesome! Thanks for the quick reply! Might I recommend updating the list to clarify that both versions are supported?
