Raspberry Pi B+ PMS failed to start
I did a fresh new install of PMS on my Raspberry but… I can’t find why it’s not working. Here is the status of plexmediaserver.service :
● plexmediaserver.service - Plex Media Server for Linux
   Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Mon 2018-12-03 16:39:53 CET; 6min ago
  Process: 17380 ExecStart=/bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver "/usr/lib/plexmediaserver/Plex Media Server" (code=exited, status=132)
  Process: 17376 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/SUCCESS)
 Main PID: 17380 (code=exited, status=132)
déc 03 16:39:48 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
déc 03 16:39:48 raspberrypi systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
déc 03 16:39:53 raspberrypi systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
déc 03 16:39:53 raspberrypi systemd[1]: Stopped Plex Media Server for Linux.
déc 03 16:39:53 raspberrypi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
déc 03 16:39:53 raspberrypi systemd[1]: Failed to start Plex Media Server for Linux.
déc 03 16:39:53 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
déc 03 16:39:53 raspberrypi systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Thanks in advance
The Raspberry Pi B+ is an ARMv6 device and does not support Plex. You need at least a Pi 2.
