Raspberry PI - No Channels found
Server Version#:
Tuner Make/Model: Hauppage Dual HD
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name: Sandy Heath (UK)
Installed Plex Server on Pi4 with Hauppage Dual HD, (just purchased). The Pi and Plex Server both recognise and communicate with the Hauppage " lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 2040:8265 Hauppauge dualHD
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub"
Plex goes through “Live TV & DVR” set-up ok, recognising my post code.
With Hauppage connected to my main external antenna (which has very strong signal and works perfectly with main TV) - Plex Server conducts scan OK but always returns “No Channels found”. Have tried by selecting local transmitter and full channel scan with same result.
Any thoughts - faulty Hauppage or some quirk using Pi - although as noted pi does recognise and communicate with the Hauppage.
Many thanks
The local transmitter settings will almost definitely be wrong, but full UK channel scan should work.
This may help Hauppauge Support | Running WinTV TV tuners and HD PVR 2 under Linux ?
edit: also Plex in Docker - Hauppauge Not Finding Channels
