As I said before, I believe this is a problem with your router.
It happens with both my Edimax Nano WiFi adapter, and with Ethernet.
My router is the latest version Apple AirPort Extreme, with latest firmware, and with no special configuration on it - should work with a standard router like that, no?
Just wanted to chime in and let you know I'm experiencing the same network speed issue where the latest build is bringing my network to its knees. I have a wired setup and it plugs into my Airport Extreme router (which is plugged into a Motorola Surfboard modem). I hadn't experienced any problems up until today when I decided to re-image on a faster SD card. Interestingly, the network becomes super slow when connected to the Pi even when I'm not playing anything on Plex.
EDIT: In thinking this issue might be related to configuration changes I made, I just started from a fresh image and made no changes to the default settings and, once again, my network came to a crawl without playing anything. It seems if its simply turned on, it sucks the life out of the network. I'm going to boot up from a fresh Xbian image next and see if I experience the same problem in case something is wrong with the Pi itself.
First up - AWESOME JOB to Dale and the team to RasPLEX !!!! Finally - my Rasp-PI Model B gets dusted off and appears to work well as a Client.
I started with 0.1.15 last week - and that seemed to work just fine !
Today I re-imaged the card with 0.1.19 - and I noticed an odd problem with what appeared to be a "network broadcast storm" when the default IP settings are in the client config.
Here is what I did)
Imaged CF card with 0.1.19
Booted into RasPLEX menu - and using Preferences, RasPLEX settings - I configured my WiFi settings to use:-
Network Technology = WLAN
Network Interface = wlan0
{I also configured my WLAN SSID / WLAN Security)
(Initially - I left the IP address to the default which I believe is 0.0.0.0 (DHCP assign?)
and re-booted the PI........
When the PI came back up - the menu seemed slow and unresponsive - but more noticeably - my other WiFi devices started to drop connections to the AP / Router; The EdiMax WiFi NANO was "thrashing" - which led me to believe something bad was happening on the WLAN network.
Once the PI was powered down - the other devices suddenly re-connected - and normal WiFi service was resumed.
BOOT 2
Now I booted back up - and configured a STATIC IP / GATEWAY / DNS Server 1 on the Preferences // RasPLEX Settings // Network
Again - reboot the PI - and now all seems OK.
So, IF you are seeing super SLOW network - have you set a STATIC IP address for the Rasp-PI? Try it - and report back......
Just wondering though, I'm trying to use disk utility to put the img file onto my SD card. Everytime it fails and comes back with 'Could not validate source - Invalid Argument'
Anyone had any similar and know what's causing this? Happens with 16,17,18 and 19. If I run it via terminal it works but then for some reason after first couple of boots on pi, all of a sudden it can't find the system folder and halts the boot.
Really not sure what's going on. Just re-flashing the SD card again.
Did you assign a static address from Rasplex or give it a static mapped address (DHCP) via your router? I don't think this has anything to do with routers. I use Sophos UTM 9 on a virtual machine as my router and the comprehensive logs show nothing out of the ordinary.
I gave it a static IP in the Rasplex settings and rebooted. Didn't help unfortunately.
My Rasplex freezes after a few seconds. Around the time it connects/communicates with my receiver (see picture). I have tried v1.19 and 1.17. Same problem.
Before it freezes it is responsive to keyboard input, and it connects to Plex server (I see the Plex server name at the top of the screen)
I do not think it is a HW problem between receiver and RPi because OpenElec and RaspBMC works.
RPi is connected to receiver with HDMI, and is on a wired network.
We'd need some volunteers to try a new test release (rc20) on which we are having various behaviours. Works fine on some of us, and not very well on some others.
Right now we have too few testers to makesconclusions out of what we see, so if you feel like helping that would be awesome ;)
Maybe you can get us some info by checking the logfile and se if you can see any errors.
Logfile should be located in /storage/.plexht/temp.plexhometheater.log
Thanks for the reply. I have the same problem with rc20 (rasplex/rpi freezes). I am not able to ftp the RPi, and when I put the SD card in my win-PC I don't see the folder 'storage'. I don't know how to get hold of the log-file.
