Just re-flashed the latest Rasplex 9.9.18 to a Class 10 SD card.
When playing a movie or tvshow after a couple of minutes Rasplex reboots, tried this a couple of times same issue, copy of log file attached.
Regards
Regards
Trying to attach log file.
I had same issue with version 9.9.17 yesterday. It kept rebooting after some minutes when I was watching a TV show. Tonight I will install 9.9.18 to see if it's the same.
Audio / video combo? Network configuration?
issues here too. love everything about this release except it hard freezes 1 - 2 minutes into any movie I've tried to start.
have similar to this.
Playback is completely busted in this version, back to 9.9.16!
For me playback is only busted when transcoding video's. So when I change setting 'Local Video Quality' from "Direct Play" to "20 Mbps" (or lower) it just won't start.
Not even shows a black screen first. On Direct Play mode it plays fine (but needs to buffer all the time because it streams over WiFi).
UPDATE: disabling the AC3 and DTS passthrough settings fixed transcoded playback for me! :D
Playback is only a problem for me on 9.9.18 when Preferences > Playback > Advanced Video > Adjust display refresh rate to match video" is enabled. At which point huge volumes of nastiness happen within 2-3 mins of starting a 24p movie - dropouts, flickering screens, crashing, lockups all sorts of horrible. Turning off this option resolves all the issues for me, but of course I can no longer do 24p content properly.
This feature was working fine on 'current' build.
Another thing to consider is the fairly intense first-time pre-caching operations that these experimental RasPlex versions perform when connected to a main PMS account (it's different for shared access).
Tests made before the initial caching is completed may well be affected by those operations, resulting in failures that would not occur if testing the same videos later, when image caching is complete.
Best regards: dlanor
I waited for the initial cache to complete - CPU was down relatively low and stayed low while not adjusting refresh rate, but was up in 85-90% soon as it went into 24p "mode". Most puzzling.
I can confirm that enabling "Preferences > Playback > Advanced Video > Adjust display refresh rate to match video" makes video unplayable...
Not just me then. I’d better check out how to raise a ticket. It wouldn’t do for this build to make it to current…
I did this and tested it on 4 movies. One did not play, one played audio only, and two played with no issues (ran for 20 minutes each).
That report would be more meaningful with framerate information for each of those movies, paired with their playback results.
Setup
Raspberry Pi: Model B 512 RAM
SD Card: 8GB Class 10 Micro SDHC card
RasPlex: 9.9.18 (installed via windows gui installer)
Plex Server Version: 0.9.8.18
Connection: Ethernet
Plex server: Local
Power supply: Powered via TV USB
Moive One
Media info from Plex server:
plexhometheater.log:
Display resolution ADJUST : 1920x1080 @ 60.00 - Full Screen (16) (weight: 0.160)
10 minute test result:
Playback: No issues
Pause/Resume: No issues
Stop: No issues
Moive Two
Display resolution ADJUST : 1920x1080 @ 24.00 - Full Screen (20) (weight: 0.001)
Playback: No issues
Stop: Screen stays blank
plexhometheater.log output:
22:15:47 T:2570273888 NOTICE: COMXPlayer::OnExit() 22:15:47 T:2570273888 NOTICE: OMXPlayer: closing audio stream 22:15:47 T:2570273888 NOTICE: Closing audio stream 22:15:47 T:2561885280 NOTICE: thread end: OMXPlayerAudio::OnExit() 22:15:47 T:2570273888 NOTICE: OMXClock using video as reference 22:15:47 T:2570273888 NOTICE: OMXPlayer: closing video stream 22:15:47 T:2570273888 NOTICE: Closing video stream 22:15:47 T:2524079200 NOTICE: thread end: video_thread 22:15:47 T:2570273888 NOTICE: OMXClock using video as reference 22:15:47 T:2570273888 NOTICE: COMXPlayer::OnExit() deleting demuxer 22:15:47 T:2570273888 NOTICE: COMXPlayer::OnExit() deleting input stream 22:15:48 T:2720003168 WARNING: CPlexDirectory::ReadMediaContainer root name MediaContainer 22:15:52 T:3046580224 WARNING: Previous line repeats 3 times. 22:15:52 T:3046580224 NOTICE: OMXClock using video as reference 22:16:43 T:2917135456 NOTICE: Previous line repeats 1 times. 22:16:43 T:2917135456 WARNING: CPlexDirectory::ReadMediaContainer root name MediaContainer
Moive Three
Playback: No issues
22:35:32 T:2677728352 NOTICE: COMXPlayer::OnExit() 22:35:32 T:2677728352 NOTICE: OMXPlayer: closing audio stream 22:35:32 T:2677728352 NOTICE: Closing audio stream 22:35:32 T:2562593888 NOTICE: thread end: OMXPlayerAudio::OnExit() 22:35:32 T:2677728352 NOTICE: OMXClock using video as reference 22:35:32 T:2677728352 NOTICE: OMXPlayer: closing video stream 22:35:32 T:2677728352 NOTICE: Closing video stream 22:35:32 T:2570982496 NOTICE: thread end: video_thread 22:35:32 T:2677728352 NOTICE: OMXClock using video as reference 22:35:32 T:2677728352 NOTICE: COMXPlayer::OnExit() deleting demuxer 22:35:33 T:2677728352 NOTICE: COMXPlayer::OnExit() deleting input stream 22:35:33 T:2999972960 WARNING: CPlexDirectory::ReadMediaContainer root name MediaContainer 22:35:35 T:3045707776 WARNING: Previous line repeats 3 times. 22:35:35 T:3045707776 NOTICE: OMXClock using video as reference 22:35:53 T:2941252704 NOTICE: Previous line repeats 1 times. 22:35:53 T:2941252704 WARNING: CPlexDirectory::ReadMediaContainer root name MediaContainer
Moive Four
Display resolution ADJUST : 1920x1080 @ 24.00 - Full Screen (20) (weight: 0.000)
Playback: No issues
22:55:01 T:2662327392 NOTICE: COMXPlayer::OnExit() 22:55:01 T:2662327392 NOTICE: OMXPlayer: closing audio stream 22:55:01 T:2662327392 NOTICE: Closing audio stream 22:55:01 T:2543256672 NOTICE: thread end: OMXPlayerAudio::OnExit() 22:55:01 T:2551645280 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete 22:55:01 T:2662327392 NOTICE: OMXClock using video as reference 22:55:01 T:2662327392 NOTICE: OMXPlayer: closing video stream 22:55:01 T:2662327392 NOTICE: Closing video stream 22:55:01 T:2551645280 NOTICE: thread end: video_thread 22:55:01 T:2983195744 WARNING: CPlexDirectory::ReadMediaContainer root name MediaContainer 22:55:02 T:2662327392 WARNING: Previous line repeats 1 times. 22:55:02 T:2662327392 NOTICE: OMXClock using video as reference 22:55:02 T:2662327392 NOTICE: COMXPlayer::OnExit() deleting demuxer 22:55:02 T:2662327392 NOTICE: COMXPlayer::OnExit() deleting input stream 22:55:02 T:2722100320 WARNING: CPlexDirectory::ReadMediaContainer root name MediaContainer
