RasPlex 9.9.20 - Can't turn TV off
I've got RasPlex 9.9.20 running, and it's connected to a Vizio 37" TV - I use the Vizio remove via CEC.
With this latest update, if I turn off the TV, 15-20 seconds later, the rpi turns the TV back on.
Any ideas? Is there some setting I'm missing to disable this?
Thanks.
Preferences -> System -> Input Devices -> Peripherals > CEC Adapter
Select the options you want in there.
Specifically, set the option which involves what to do when a device turns off, set that to Ignore (default is Suspend - which actually reboots the RPi, which in turn turns the TV back on)
This behaviour will be fixed in next release :
https://forums.plex.tv/topic/102612-rasplex-040-is-coming/
