Rasplex fail if not casting
I completly redid my plex server, router and raplex with the newest versions and still get "dir retrive error" and sudden stopping after 3 and 5 mins of play. Sometimes longer. I can reboot the rasplex and all is fine for a short while. I recently discovered that if from the plex server I play to "rasplex home media theater" (might have called that the wrong name)  I have no problems. Only when the rasplex is selecting the file to play.  Any ideas would be helpful. Idea of network below. *=dynamic and ip changes
                         router-192.168.1.1 (port 32400 is forward to 192.168.1.4)
                            {LAN PORTS}
|PORT1|                 |PORT2|              |PORT3|               |PORT4|
rasplex                    Drobo                                   Media-PC (win7)(PlexSrv)
192.1681.*       192.168.1.200                                     192.168.1.4
Now casting gets the “get directory fail”. Simply starting from last spot works. The files that the PMS are using are located on the drobo
A product is only as good as its support, with only a forums board as support and no replys in 4 days I guess this speaks for itself
You do realize that RasPlex is an unofficial client that is not supported by Plex. It is developed and supported by a team that is doing it in their free time so your expectation that Plex should be responding to your problem is a bit misguided.
