Just for fun - I tried "let's program the Up key" in flirc's program and hit the up key on the touch - it didn't register anything.
But - the touch is happily controlling lots of other devices - and the same flirc dongle can see an apple remote - so both ends seem to work alone - just not together.
I feel I'm missing something obvious (especially as I'm a new rpi user, a new rasplex user and a new flirc user) so any hints welcome ;)
I’ve noticed that a lot of people seem to have this problem. When I had it I ended up doing it the manual way. (Yes, I know other solutions work, but I don’t look around, I just fixed it and didn’t look back)
Since FLIRC doesn’t really care what type of remote you have, set your Touch up as any TV remote with lots of buttons (make sure it’s for a TV you don’t have in your setup, so it doesn’t conflict with your real TV - I used some random Panasonic) instead of a PLEX or XBMC device.
Make sure your buttons all have assigned actions in the harmony software and add any soft keys you want as long as they aren’t assigned to other buttons. (What they are doesn’t really matter as long as pressing it does something)
The key is that FLIRC reads in an IR signal and then just converts it to whatever keyboard command you assign, so as long as you have IR commands that FLIRC can see you’re good to go.
What type of device is your harmony setup as? I had trouble with MCE, PLEX and XBMC remote profiles. The arrow buttons didn’t work or it pressed 2 different arrows at once.
Turned out that only generic TV remote IR commands really worked for me consistently.
