Rasplex Wireless Issue
I have notice that when I reboot by rasp pi I have to restart my wirless connection.  This is not a major issue but has become a little more of a hassle since i switched to the Refocus skin.  In this skin I don't have access (that I know of) to reconnect my wirless connection so I have to switch back to Mediastream, reconnect and then switch to Refocus.  This is only a minor inconvience since I don't usually shut down my Pi, but those time when things freeze up an such it is a little time consuming.  Nice work devs.  This is really fun to play arround with and the progress really amazes me.
Yeah, you can't access the RasPlex options from Refocus.  Now that we have seen that Refocus really boosts performance, I wonder if it will be included in future updates, either as a built-in option or the new default skin.
I still got wi-fi problems on 1.37.
i am using a micronext MN-WD552B adapter, wich is working with no problems under xbian.
dmesg: http://pastebin.com/SmDTvjhF
lsusb: http://pastebin.com/ZB9UuAJ8
ifconfig: http://pastebin.com/JSjhyLDP
rasplex can see my wifi adapter and i can see the networks but when i try to connect to them it says NoReply.
I had similar issues with the original wifi-adapter I bought with my Pi. Replaced it with an Edimax adapter and now everything works perfectly.
Hey wabe,
I’m having the same problem with the usb dongle I ordered from the pi hut. Actually, I don’t know what kind of manufacturer and model this is. Could you tell me with which device from Edimax it is working for you?
Thank you! :slight_smile:
Gesendet von meinem GT-I9300 mit Tapatalk 4
I don't have the box but is pretty sure it's called EW-7811
Hey wabe, I'm having the same problem with the usb dongle I ordered from the pi hut. Actually, I don't know what kind of manufacturer and model this is. Could you tell me with which device from Edimax it is working for you? Thank you! :-) Gesendet von meinem GT-I9300 mit Tapatalk 4
Hey wabe,
thanks for your hint, I ordered this wireless lan usb stick.
Meanwhile, I checked the latest rasplex release notes and there seems to be a general issue with wifi.
Too bad my current internet connection is throttled down to a minimum via umts, getting a new landline - cause of moving - at friday.
I'll see if the update solve some problems. :)
Bye
fleischkarussel
