Rate limit exceeded error 429 when refreshing EPG
Server Version#: 1.25.4.5487
Player Version#: 4.74.1
Tuner Make/Model: XTEVE / HDHomerun
Guide/Lineup name: Vodafone TV (TEST LAB)
Using XMLTV?: No
Channel number/Name: All (only 10 channels selected)
Using the Vodafone TV EPG results in several 429 errors and stops any further processing of EPG guides. HTTP Error 429 is usually a rate limit exceeded error. The rate limit should either be increased or the server should pause and continue later / with less requests per second.
Message
EPG: received HTTP response of 429 from request to https://epg.provider.plex.tv/grid?beginsAt<=1644537600&channel=5fc705d64c4901002fec39b2&endsAt>=1643932800&X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx&X-Plex-Language=de
Message
Message
EPG[cloud]: Failed to load EPG.
