Rating not downloading?
Hi, I have Rotten Tomatoes set as my rating provider for my movie agent. For some reason ratings are not downloading for my one movie even though there is a rating for it when I check on the Rotten Tomatoes website. I have already tried refreshing the metadata multiple times with no luck. Why is the rating not showing ? Thanks.
Capture2
Think its the same issue as this thread -> Metadata: Rocketman (2019) not downloading Critic rating (IMDB) and alas no update has been forthcoming
Yup you’re 100% right ! It’s happening for me with Spiderman: Far from home…
Please do let me know if you find a solution. Thanks.
Same issue as these other 25 issues (at least), going back to 2016 (…)
I doubt there will be a solution coming any time soon. @anon5074910 seems to have made it work with tmdb agent though. Likely the ratings will still be a bit incorrect, but definitely better than Plex movie.
https://forums.plex.tv/t/not-getting-imdb-ratings-for-popular-movies/182989
https://forums.plex.tv/t/imdb-ratings-no-longer-used/226920
https://forums.plex.tv/t/server-stopped-getting-imdb-ratings-why/190583
https://forums.plex.tv/t/not-getting-imdb-ratings/152760
https://forums.plex.tv/t/imdb-ratings-missing/221562
https://forums.plex.tv/t/issues-with-ratings-imdb-and-rotten-tomatoes/210412
https://forums.plex.tv/t/imdb-ratings/195778
https://forums.plex.tv/t/weirdness-with-plex-agents-and-imdb-ratings/235915
https://forums.plex.tv/t/no-imdb-rating-at-suicide-squad-and-the-beacht-all-other-movies-work/176060
https://forums.plex.tv/t/small-percentage-of-files-will-not-pull-imdb-metadata/177150
https://forums.plex.tv/t/imdb-ratings/176222
https://forums.plex.tv/t/imdb-ratings-out-of-date/303567
https://forums.plex.tv/t/bug-plex-movie-scanner-and-imdb-ratings/329825
https://forums.plex.tv/t/plex-movie-agent-imdb-ratings-wrong-cached/161747
https://forums.plex.tv/t/why-are-fetched-ratings-inconsistent-rt-imdb-star-rating-shown-at-movies/192190
https://forums.plex.tv/t/periodically-update-imdb-ratings/2324
https://forums.plex.tv/t/plex-agent-not-downloading-imdb-rt-ratings-with-metadata/213395
https://forums.plex.tv/t/incorrect-ratings-from-imdb/314764
https://forums.plex.tv/t/problem-with-ratings-from-imdb/189973
https://forums.plex.tv/t/missing-ratings-for-some-movies-plex-movie-agent/465621
https://forums.plex.tv/t/where-have-all-the-ratings-gone/460584
https://forums.plex.tv/t/metadata-rocketman-2019-not-downloading-critic-rating-imdb/450350
https://forums.plex.tv/t/persistent-bug-metadata-being-scraped-all-wrong-help/463720
https://forums.plex.tv/t/incorrect-imdb-ratings-on-plex/428228
Ratings from tmdb are coming through perfectly on plex (at least for me) – less folks use this for rating so the % can differ from IMDB or Rotten Tomatoes but overall its good and at least from what I can see is working 100% with the plex metadata fetchers.
If your interested in tmdb you can export your existing IMDB ratings and import them into tmdb. Works like a charm but I do find myself now including my ratings on both sites :slight_smile:
@tvebax found out why. Definitely worth a read.
