Hello BigWheel
I’m kinda in the same situation.
When I click on Collections, from the web browser, It shows all my movies 1:1 in the collections tab. I would only like to see only movies that are actually part of a collection, whether I create it or Plex did. How can I do that?
Thanks in advance,
After I replaced my dead hard drive, I installed the latest Plex server version and recreated my library, so why do I need to restore the defaults? I did not create these collections.
if you are seeing the entire regular library movies (not collections) under the collection tab then restore defaults to fix it. It is not going to change your server settings.
Since all those collection are made you need to select the ones you don’t want by clicking on the circle on top left of collection posters and then delete them all from menu
One is the tab to show the library view. One is the tab for the collections in that library view. And the last is recommendations for items in that library.
In short you’re just seeing different views of the same library.
