Recent update has disabled Remote Access
What’s up Plex Ninjas?!?
I’ve encountered this issue numerous times in the past, and it’s quite frustrating. After a PMS build update, I am no longer able to access my server from outside my local network. My modem/router is an Arris TC862G/CT and is UPnP compatible. I have deleted and re-entered Port Forwarding Rules pointing to port 32400 every time. TCP/UDP combo setting is the only one that works. This issue will show my Remote Access disabled for weeks or months, then when I go and delete the Port Forwarding rule again and re-enter a couple of months later, it is fine. Has anyone else experienced this?
