We can’t even do that with the Android TV Plex client.
At some point most sane people would say oops and roll back the mistakes.
OK, the “Manage Hubs” screen has only one button that allows me to edit the order of the hubs. There are NO hubs listed, but I could (I assume) change the order if there were any.
I have tried using the “Restore default home screen” option, but it remains empty. I cannot find any way to ADD (or remove) hubs to the manual home screen.
I’m having this exact problem on one of my Rokus. The others are doing just fine. But there’s nothing to edit, nothing to choose or move. And restore only refreshes. When I go to “Home” There’s nothing there except a notice that says “Personalize your home screen. You can add your favorite content to your home screen. Press * while on any row of recommendations and pick ‘Add Hub to Home’.” Below that there’s the “Manage Hubs” and below that there’s “Restore default home screen” - both of which, as I said at the beginning, are useless.
Is there a way to solve this???
Tina
What happens when you try this?
Thanks for the quick response. There was no recommendations showing, so that wasn’t an option.
So I decided to try signing out and signing back in and that FIXED it!! Everything shows as it should.
Thanks!!
Tina
I’m having the same problem.
The complete home screen is messed up, but it’s funny that it doesn’t happen to all of my friends.
I want my old combined view back, serverwide. T_T
I have found a solution for this. I know manual setup has not worked for everyone (myself included) but there’s more to do after you go manual, then go to sort/hide, etc. Get rid of ALL recently added, then go to your sidebar, go down to your main Movie category and to the left select the 3 dots, go to hub and just select the recently added (make sure it shows the house icon, may have to select 2xs) then do the same for TV shows & boom! 1 recently added & ALL recently added from all categories will show up… You’re welcome
