I’m looking for a plug-and-play remote control for RasPlex. It should work out of the box with RasPlex. Can anymore recommended a remote which is as simple as the Apple Remote?
Thanks and regards,
igno
I’m using this:
http://flirc.tv/
It works out of the box and you can easily configurate any remote.
The only problem is that it does not support long presses.
Do you have an iOS or Android device? You could use one of those.
