Recommended category
Please please please make the LIBRARY category the default choice before RECOMMEND, who really need a category that show only part of a library, have to change this each time I install Plex or after some updates.
If you enable this option, Plex will return to the Library tab each time.
Yes I know that but I would preferred to not have to change that in the first install of the app, or after an IOS update I have to re-check these choice to all my library and I find it really awkward, I think it is not hard for you to change these options, and that an app choose for me what is RECOMMENDED.
There are undoubtedly some who prefer the Recommended tab, so this would have to be a setting somewhere that allows the user to select which tab they want new libraries to default to.
Do a survey and we see.
