Record location for TV show - Only movies library shown
I have an issue where the EPG downloads fully but when I select a TV show to record the only save location I can select is the movies library for obvious reasons I don’t want this. Is there anyway to fix this other than using an XMLTV feed?
Server Version#: 1.27.1.5891
Tuner Make/Model: HD Home Run Quadro
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name:
It just means that this airing is not marked as part of a series in the EPG. It usually also means that there is no information about the season and episode numbers of this particular episode.
There is unfortunately nothing you can do about it.
