Record New and Repeat Airings" does NOT work unless ... PLEASE FIX
Server Version#:
Tuner Make/Model: Hauppauge Quad software version 10
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
… unless the first recording was a NEW recording (Hence “New and Repeat Airings.” That is, if the first recording is a RE-RUN, therefore NOT NEW, no repeat airings will be recorded by Plex. Either “New and Repeat Airings” should work with RE-Runs, or a new category called “RE-Runs and Repeat Airings” is needed.
Easy enough for you to consistently repeat this problem. This is what I did …
1.) Set up a NEW program to record “New and Repeat Airings.”
2.) Set up a Re-Run (say like Hogan’s Heros or Becker) to record “New and Repeat Airings.”
3.) After the Second airings have occurred the Repeat Airings of the NEW program will be listed as “Copy 1,” Copy 2,", etc.
4.) There will be NO copies of the Re-Run.
Can this be fixed so that repeat airings of Re-runs also are recorded?
Thanks,
biker.bookkeeper
Phoenix AZ
Windows 11 Pro, Plex Media Server I am only able to record using the Version 1.40.5.8921.
If I update I cannot click to record without it failing in the end or setup to record a new airing or another specific show.
Looking for help from PLEX moderators
I use HDHomeRun Extend, HDHomeRun Quattro, HDHomeRun Flex 4k
