Thanks for adding the logs for the failure from the 24th December.
in this case - the error text Please check your tuner or antenna was not representative of what caused the error. It is not always easy to get the right text for error messages for each case.
The logs network failure on the Shield that and loss of connectivity to the local network and the internet as well. This happened at 09:05 am on the 24th December. This of course led to the failure of the transcoder communication with the tuner
Dec 24, 2018 09:05:41.416 [13706] DEBUG - NetworkInterface: received Netlink message len=1268, type=RTM_NEWLINK, flags=0x0
Dec 24, 2018 09:05:41.418 [13706] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=4, flags=0x11003, change=0x0
Dec 24, 2018 09:05:41.418 [13706] DEBUG - Network change.
Dec 24, 2018 09:05:41.418 [13706] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 24, 2018 09:05:41.419 [13706] DEBUG - Network change notification but nothing changed.
Dec 24, 2018 09:05:45.587 [13706] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_GETADDR, flags=0x0
Dec 24, 2018 09:05:45.587 [13706] DEBUG - NetworkInterface: Netlink address message family=2, index=4, flags=0x80
Dec 24, 2018 09:05:45.587 [13706] DEBUG - Network change.
Dec 24, 2018 09:05:45.587 [13706] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 24, 2018 09:05:45.589 [13617] DEBUG - MyPlex: We appear to have lost Internet connectivity, resetting device URL cache.
and you can see that the network interface is no longer available
Dec 24, 2018 09:05:45.592 [13706] DEBUG - Network interfaces:
Dec 24, 2018 09:05:45.592 [13706] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
All communications were failing at this time, eg
23897 Dec 24, 2018 09:05:45.607 [8336] ERROR - Error issuing curl_easy_perform(handle): 7
23898 Dec 24, 2018 09:05:45.607 [8336] WARN - HTTP error requesting GET http://plex.tv/pms/:/ip (0, No error) (Failed to connect to 63.32.24.1: Network is unreachable)
and the transcoder aborted for same reason - as it lost its connection to the HD Homerun on 192.168.2.75
Dec 24, 2018 09:05:45.610 [7921] ERROR - [Transcoder] http://192.168.2.75:5004/auto/v15.1: Software caused connection abort
Unfortunately the error given by Plex Media Server is not accurate
Dec 24, 2018 09:05:45.794 [13624] DEBUG - Jobs: '/data/user/0/com.plexapp.mediaserver.smb/Resources/Plex Transcoder' exit code for process 9296 is 1 (failure)
Dec 24, 2018 09:05:45.794 [8334] DEBUG - Streaming Resource: Terminated session 0x22dea26ba0:be8d5a17-a4ab-47ec-a7c6-a8a0f6435e2e with reason Recording failed. Please check your tuner or antenna.
The network interface came back to life at 09:05:56
Dec 24, 2018 09:05:56.384 [13706] DEBUG - Network interfaces:
Dec 24, 2018 09:05:56.384 [13706] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
Dec 24, 2018 09:05:56.384 [13706] DEBUG - * 4 wlan0 (192.168.2.78) (loopback: 0)
I have no idea as to why the network connection failed on the nVidia Shield but it would not be a Plex issue
