I recent,y updated my EPG to ICETV and so needed to reset all my recordings. Easiest way is to find the show in the list of all shows in TV mode and then record all episodes. However when I did this and then went to check the recording priority all but one had disappeared. This happened several times so I gave up and went back into the classic view mode and went to the guide and set the recordings from there(harder because you have to find the shows and when they are scheduled). This way worked though and all remained listed in the priority listing.
I have previously scheduled recordings by just browsing through the all shows so this is new problem. Not sure if it is related to ICE EPG but it is pain to switch the EPG just to test and will need to reschedule everything again so only want to do that as a last resort.
Thoughts?v
