Recordings not recording
Recordings will not record duplicate names. Recordings is not reconizing the years.
Examples:
in library “Total Recall (1990)”
recorder will not record “Total Recall (2012)”
I had to Remove the “total recall (1990)” folder from the library and copy to a windows temp folder, before the recording would actually record the Movie.
Other examples:
a Novel Romance (2011)
a Novel Romance (2015)
Same thing, i had to move the original directory to a temp windows folder before the recording would show up in the right pane to record.
Robocop (1990)
Robocop (2012)
I have also had problems when i have a 720 by 480 dvd version of a movie and i wanted to record a HD version.
Example:
Into the Blue (2005) standard definition
Into the Blue (2005) High Definition
the High definition would not record or even schedule a recording until i move the original directory to a windows temp directory.
then it scheduled the recording and worked, also under the recording advanced settings, the replace lower resolution files with HD was checked.
Thank’s for fixing
fjruhl@gmail.com
