Recordings Stopped After Update
Updated to Version 1.13.6.5339
Since the update none of my recording will record.
They show in the guide as a new airing and have the record icon next to the title.
When I go to my recordings it’s blank.
For troubleshooting I’ve re-scanned channels, did not fix
Removed my HDhomerun and re added it, did not fix.
Examples, 60 Minutes and Big Brother (both new for 8/26/18)…
This is still and issue, and frustrating as we pay for the CableCard in the HDHomeRun…
Now it just a live only system without DVR.
What do the Plex logs say for the shows?
What logs should I pull?
Plex Media Server logs are the ones to look at when Plex is scheduling recordings.
I read in another thread that the guide is no longer indicating which shows are HD so if the recordings are set to HD only, the show won’t be recorded… does that jibe with what you’re experiencing?
Yes! All my recordings are set to HD only.
So would this be a bug?
I set everything to HD only to be sure we get the best quality.
If I set it to not HD only will I get SD recordings too?
I guess I don’t have a choice now.
I think it might be possible to specify the exact channel for the recording so you could always make sure to choose the HD channel. (Yes, under Show Advanced when you’re setting up or modifying the recording).
