I can not remove the HD Homerun tuner and it wont download the guide just sits spinning.
Mac:
|System Version:|macOS 10.13.6 (17G65)
| Kernel Version:|Darwin 17.7.0|
HD Homerun:
Model: HDHR4-2US
Device ID: 1046F537
Firmware: 20180817
Plex Server:
Server Version#:Version 1.13.8.5395-10d48da0d
Player Version#: Web and Fire cube TV
I am experiencing the same issue on my system with a similar setup, iMac on macOS 10.13.6 utilizing HDHR4-2US on the same firmware version running Plex 1.13.8.5395. The issue started a little over a week ago. You can’t do anything with DVR or Live TV, including delete it.
Only way out is to delete all plex software folders and uninstall. Its a pain becuase your have to rebuild your database, I had a bunch of collections I built and Im getting tired of rebuilding my database this is my 3rd time
I’ve been having this same issue for probably 2 or so months now. Has anyone else experienced this issue and resolved it without resorting to the nuclear option?
Unfortunately I couldn’t find any alternative either. I tried deleting just pieces from Cache and other settings, but overall I ended up having to completely remove Plex and start clean. I did have a backup of Plex, and going back to the older version prior to experiencing the issue seemed to work, but presented with other slowness remotely so a clean install was really my only viable option.
I may have managed to resolve this issue by deleting the 3 “tv.plex.providers.epg.onconnect” files located in PMS/Plug-in Support/Databases on my server and then rebooting.
It took forever to rebuild the Guide database after reboot, but it managed to make it all the way to 100% and it has been good for a few hours now.
