Update: The person on github who stated this resolves it (which it appears it has fixed mine also) posted this on the plex forums. 1.32.x Breaks Plugins on Windows (OpenSSL)
Yep, it is working for me as I setup a new Plex library and it is scanning items correctly like it was before.
Update: everything is scanning in correctly, like these last three weeks were just a bad memory. Will note, you might need to setup a brand new library with the Youtube agent and using TV Show or Movies library (depending the content) to get things to scan back in correctly, but all my things are scanning in like they should be and the metadata is working to sort by release date correctly.
I’ve tried with multiple Scanners and the YouTube metadata agent. For the Absolute Series Scanner that youtube metadata recommends I can see it grabbing and setting the correct date. So the issue seems to lie somewhere between the agents and scanners.
Something else interesting is the Tautulli recently added notification will display the correct episode name from the metadata even though Plex can’t seem to find it
I recently moved away from the metadata agent and started embedding the metadata into the mp4 with yt-dlp. Saything that, the meta agent does work. I used it for years, I just figured removing a link in the chain was probably for the best looking at how Plex is evolving.
I’m not sure what I’m doing wrong, I used to use the binhex docker image but now using the offical Plexinc image and cant get the YouTube agent to show up for TV Show libraries. I have deleted and reinstalled all Plugins even tried using the files I used for my old setup still no agent. com.plexapp.system.log (46.8 KB)
Did anyone else’s Youtube metadata stop scanning today? I noticed as of 6 hours ago, no recent Youtube videos have metadata. Doing a refresh metadata doesn’t appear to be working either. I am running on a Windows 11 Pro machine Plex server 1.41.7.9799
With the release of the new MetadataAgent subsystem do you know if you will be updating this MetadataAgent? No pressure, just wondering if I should start looking for an alternate solution now or wait for you to release something?
I agree. I just put together a new server (and didn’t want to copy all my data from the old one) and installed this agent. It doesn’t even appear in the drop down options for “Agent” in my libraries……
FYI: I did find this comment that will allow you to re-enable the old python agents, but it still doesn’t pull any metadata. I even copied my old plugin directory from the old server to see if that would do it but nothing:
