Hi all,
I’ve just moved my Plex instance to a new device. Local connections are working fine, but the relay is not. The relay is enabled under Network->Enable Relay, Secure connections are set to “Preferred”. I’ve tried turning the relay off and on, as well as restarting the system multiple times.
The relay binary appears to be crashing; I’ve grepped “relay” from the logs and pasted it here: relay_fail.log · GitHub
Any ideas? My guess is that it has to do with moving the server (performed using instructions from Move an Install to Another System | Plex Support), that somehow has the relay servers confused.
