remote acces is not working, wrong IP.
Yes, My apologies. Been very busy.
Can you stop all scanning / playback for a moment and Optimize the database?
Also, in Settings - Server - Scheduled Tasks - Make sure database optimization is enabled? Your database is terribly slow. (fragmented)
com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F12900236
Aug 06, 2018 23:23:22.550 [0x7f6d9180b700] WARN - SLOW QUERY: It took 230.000000 ms to retrieve 51 items.
Aug 06, 2018 23:23:22.630 [0x7f6d89111700] WARN - SLOW QUERY: It took 530.000000 ms to retrieve 50 items.
Aug 06, 2018 23:23:29.697 [0x7f6d89111700] WARN - SLOW QUERY: It took 290.000000 ms to retrieve 50 items.
Aug 06, 2018 23:23:51.470 [0x7f6d82f35700] WARN - SLOW QUERY: It took 300.000000 ms to retrieve 51 items.
Aug 06, 2018 23:23:51.513 [0x7f6d80911700] WARN - SLOW QUERY: It took 580.000000 ms to retrieve 50 items.
Aug 06, 2018 23:23:51.569 [0x7f6d8ca23700] WARN - SLOW QUERY: It took 260.000000 ms to retrieve 51 items.
I see where PMS is talking fine. What I see the most of is PMS not being able to communicate between the modules because of the DB.
Would you mind if we address this first?
No, I would not mind doing that first - appreciate everything. you are doing.
  • Settings - Server - Scheduled Tasks - Make sure database optimization was enabled
  • I have also optimised the database manually just now.
J.
Restart PMS please.
With the DB optimized, give everything a fresh start. It will behave better
done. …but there is no “restart” button, right? I am stopping and starting the app from within QNAP app centre.
Yes… I had assumed that was obvious :slight_smile:
I thought so, but suddenly thought that maybe there was a “restart” button akin to soft-resetting your phone (as opposed to switching it off and on again).
…is there anything else I need to do?
cheers :slight_smile:
No… Go for it… “Adjust for maximum smoke” :slight_smile:
Thanks for all your help!
@ChuckPa - woke up to Plex remote access being down 4 times in. the last 2 hours (still down right now)… :confused:
…I just manually disabled and re-enabled and it came straight back up. …will monitor.
I had a similar problem where Plex would obtain the wrong IP address on my QNAP. It turns out that it was conflicting with my docker container. If I disable my docker container, Plex would be able to get the correct IP address. It looked like the docker container added some network configuration to my adapter 1 (VPN related I believe)
