So I am new here and setup my Plex will not let me have remote access. i have tried port forwarding with no resolve and asking for help with this frustrating last step. Thanks!
I am on a Cox Panormaic Wifi Router on a single home network. Tried port forward to 32400 and no good
First, suggest deleting that picture since it shows your public ip. (thanks mods!!)
Who is your isp? Do you know if they have you behind CGNAT? Can provide steps to check if needed.
What’s your network setup like, just a single Router/gateway or multiple devices?
If you know you’re not CGNAT…
For port forwarding, did you click manually specify on the plex remote access page, enter a random port, or use 32400, and then created the forwarding rule on your router? If you need help with creating the rule, share screenshots and the router model.
Based on the screenshot plex is trying to use UPnP to handle the port forwarding and can’t open the port. You don’t want to use UPnP anyway. Should ensure it’s disabled on your router/gateway.
Did you test the port with this to see if it shows open?
Did you try a different port, not the default? If so, internal will remain 32400 and external will be the port you set in plex.
Did you confirm the windows firewall is allowing port 32400 and plex through, if it’s enabled? Also, is the network connection in windows set to private?
Does cox have any advanced security features? If so, disable them. They can interfere with port forwarding.
Share screenshots of the rule you created. Only thing to block out is the public ip. Dont need to block out internal/private IPs.
Are you in Las Vegas by chance? It seems Cox is using map-t in some markets, Vegas being one, which is similar to CGNAT (I don’t really know how it works, just from quick reading online in the past), and restricts the ports you can forward since you still share a public ip with other cox customers. With map-t, usually there’s a way to opt out or use specific ports. But I’m not familiar with the cox setup.
You may be able to contact cox support and see if they have other methods.
I didn’t dig into the details, but it seems using your own router will give you your own ipv4 and allow port forwarding.
One post about it where the most recent comment from the original poster was they had to use their own router to get it working:
