Remote access capped at 2-3mbps even with no relay and direct play
Server Version#: 1.41.3.9314 - Docker on Unraid
Player Version#: Latest on various: Android, Samsung Tizen OS, etc.
Remote access used to work until recently. Local streams work fine, tested on various files of different bitrates. Remote access is where the issue happens for some reason now. Relay has been disabled, port forwarding was verified and I even changed the port number to be safe. Internet is 1000/1000 with no data caps, I scrubbed through all the settings but didn’t see anything where a hiccup could have happened? See below for screenshots, thanks in advance!
