Remote access disabled
My remote access ever works fine, but in the past 3 days, it go red 30secs later than i connect it
the console report this
PublicAddressManager: WAN IP on router does not match public IP from plex.tv
how i can fix it?
that means you have likely have a doublenat. though your screenshot looks like a standard public IP. probably will need you to explain how your network equipment is set up and/or what sort of ISP you have (like if your ISP has you on a CGNAT)
I’m a bit of a noob at this, how can I know what kind of ISP I have?
My network equipment is a PC where I have stored locally the content connected by cable to the router of the internet company, and it has worked well until now without touching anything.
The Router is a ZTE ZXHN F6640
What is your ISP company. Maybe someone here has the same.
Did you do the manual port forward set up in your router?
Euskaltel, in Spain.
I didnt set up ports in the router but never need to, it works fine until 2 dyas ago without change anytinhg
When it comes to your internet connection and remote access, it’s not just about what your configuration looks like but also about a number of other „players“… namely your internet provider. They can change a lot of things on their side that can impact your remote access — up to the point where they break it for you.
You can check out this thread to pin down what’s causing your issue. Though your description implies this might be due to a change on your internet provider side.
All ok now.
My ISP make my connection into CGNAT, and cause this.
I call they, ask for take me out of CGNAT and gave me a public ip and everything works fine now.
Thanks a lot people
