Remote Access Disabling
My remote server will not stay connected. When i reboot my router it will stay connected for about 30-60 minutes. If i hit retry to connect it stays connected for about 5 seconds. I’ve tied upnp and port forwarding. currently i have it as a manually routed port. I’ve tried searching for solutions but found nothing. i have my logs just not sure which ones i need to post. I also have the latest server downloaded. Any help is appreciated.
Server Version#: 1.16.4.1469
Check canyouseeme.org for success on your Port forwarding.
its open
Next time it fails check maybe you have a twonky router…
router is brand new orbi. was having the same issues with my last router as well which was a nighthawk. i have full internet connection on it. works perfect on lan network. just the remote access keeps disabling
Look at what I posted here
Unfortunately this didn’t work either
please have same problem with amplifi router … its connect for few second and disconnect again .
i did everything … port forward … enable UPNP … nothing working … i am using mycloud home server
On my Nighthawk I have the firewall disabled. Have never used that function anyway, but that could be it. it also could be Windows built in firewall blocking that too.
You could setup your PMS on the DMZ (in router). That would def tell you if it’s a port issue if it does work on DMZ. Setup your PMS with a static IP and then add to DMZ.
