Remote Access has stopped working
Server Version#: 1.43.0.10492
Player Version#: https://app.plex.tv/desktop/#!/
I have an issue over the last day. My remote access disconnects shortly after being reconnected. I can access my server @ http://127.0.0.1:32400/web/index.html#! on the server itself, however https://app.plex.tv/desktop/#!/ on the server does not allow access to the content saying ‘No Content Available’. I have a mapped port forward of 32400 on TCP which has been working perfectly. My server name is Maxserver, and I’m running version 1.43.0.10492
[mod edit: your certificate is perfectly fine. But I noticed that you have requested a new certificate almost daily during the last 4 weeks. Are you erasing data in the Plex data folder? Don’t do that indiscriminatively. There are only certain subfolders where daily clearing may make some sense. Please create your own forum thread for any followup questions.]
I am not erasing any data knowingly in the Plex Data Folder, and the current server build has been running for a few years with no issues.
What logs can I supply?
The initial green status doesn’t mean anything. It is green while the server is actually testing the connection and then turns red if the result is negative.
Even so, something could have changed in your own network, or on your server, or at your ISP.
  1. verify that your server’s network connection is labelled “private”. It must not be “public”.
  2. continue with The Basics of Remote Access Troubleshooting
My server has a private (and static) ip address. I’ve deleted my Port Forward rule, and reinstated it, then tested successfully on Open Port Check Tool – Verify Port Forwarding on Your Router
The windows Plex app on another PC on the same network can connect with no issue, but the Plex web can’t
If this is about the web app accessing the server in the local network, you may want to look at
I’ve already checked the Local Network Access on Edge on the server. The android Plex app on 2 different devices on the same network gives the connection issue, whilst the windows app doesn’t?
Check out the second link. It lists a whole lot more to verify.
Sounds like a DNS issue.
I have Bitdefender total security installed on the server. I’ve tried disabling the firewall temporarily, but that didn’t help the issue. I’m able to access the content on a different pc using http://server.local.ip.address:32400/web
Point 2: Client says it won't play from "remote server", although the server is local
I’ve set the external port number to a different one from 32400, and updated the Plex settings to use the same number. Again, it temporarily shows green but then no external access. Canyouseeme is able to connect to that port number with no issue. I had already set Plex to be IPv4 only
I’ve setup DNS on the server with Google Public DNS for both IPv4 (see picture) and IPv6 , but still have the same issue with no connectivity. Canyouseeme is still able to connect to the port with no issue.
I’ve tried the other options with no success
Have you considered, that your ISP may have put you behind a Carrier-Grade NAT?
Mine has stopped working abruptly yesterday as well. I can use the Plex App on my TV but cannot on my Android phone even while at home connected to the same internet.
IP is on private, nothing has changed with the router.
How would you find out? Everything else on the network has no difference?
Websites like https://canyouseeme.org/ will show you your public IP address when you visit them.
Compare that IP address with the one which appears as “public/WAN” in Plex and your router interface.
If there are different addresses, chances are high that you are in a double NAT or CG-NAT situation.
The external IP address on my router matches the one shown on whatismyip.com and also matches the IP address on Plex
I’ve also tried enabling DNS over HTTPS, but no difference.
That’s a good thing.
Though I do see that the certificate abuse is continuing. Every day your server is requesting a new certificate. What are you doing with that machine? Is there a script deleting data daily? Is there some other app resetting things every dozen hours or so?
The only thing that I have scheduled is the Plex check for new media every 12 hours. I’ve disabled that for now.
MAJOR UPDATE!! A friend who uses my Plex server using a firestick hasn’t been able to access anything for the last week as well. I noticed him appearing as streaming something this evening, and rang him. On his firestick, he had set the network security requirements to Insecure (like you used to be able to do on the server itself), and can now access all my content from a totally different city.
It must be something that has changed in the app itself!
