So like many others are seeing the PMS remote access is randomly disconnecting. I have been running PMS for years and over the last few months this has begun to happen. The temporary fix is easy, just disable remote access and the re-enable it. Problem is that is will just randomly disconnect again. This is very frustrating.
I have checked there is not double NAT situation and none of my routers have changed, same FiOS service as well. I have tried removing UPNP and manually port forwarding but this did not solve my issue so I put UPNP back on.
I looked at my server logs but I am not sure what entry I am looking for. I have attached them here, can anyone help me diagnose the cause of the problem? Thanks
I think it’s a temporary outage of a part of Plex’s system - namely plex.tv - as seen here: https://status.plex.tv/ that is causing these remote connection problems.
