Remote Access is very inconsistent. Doesn't stay connected
Server Version#: 1.17.0.1709
Player Version#:it varies
I have a windws 2012 server with Plex server installed. It is inside my home ethernet network… This server is connected via a gig connection into a FIOS router. The windows 2012 plex server does not have the firewall enabled and does not have any port monitoring/blocking software. I verified that. I do not have a static ip address for my home but it very rarely changes if ever. I gave remote access to a friend but can also verify on my side that the remote connection consistently goes up and down. Initially I thought it was because my ip address from FIOS was changing but it is still the same. I have tried opening port 32400 but it didn’t seem to help. Is there a timeout when my plex server connects with http://plex.tv (or wherever it talks to) ? Is there anything I can tweak if there is a timeout? When my friend tries to connect, he may have to try 3 or 4 times but it eventually starts working. Again, I can see this on my side also when looking at the status of the remote connection from within the server GUI so I know it isn’t just his connection. I have also verified the same thing from my phone when it is not connected into my home network via wifi. The windows 2012 plex server is up almost 24/7 except for routine maintenance. I am just not sure where else to look as I am 99% sure it is nothing to with my my network since I have tried all of the options I have found (ie port forwarding etc). Is there a parameter in an XML file or similar that configs how often my server checks in with plex.tv?
Any ideas are welcome at this point.
This topic was automatically closed after 90 days. New replies are no longer allowed.
