Remote Access issues
I have a Plex Media Server and cannot figure what is going on with it. I cannot enable Remote Access outside my network. It enables for 4 seconds and then disables.
version: 1.18.4.2171
ISP: Comcast Xfinity
all the ports are open correctly on my ASUS TM-AC1900 router for port forwarding. I have been having this issue for the past 2 months
Please don’t hijack other posts… while the other user’s issue might be on the same topic, your issue is likely different.
Let’s get started from top.
  • Have you checked if you can play content from your Plex Media server while outside your home network despite the status indicator claiming remote access is off?
  • Can you access the forwarded port at on the public IP of your Asus router from outside your home network? You should be able to test this with e.g. canyouseeme.org
