Hi Elan, nice to salute you, hopefuly i can get a little hand here, ive tried to enable remote server access, everything its set in the router, but it said connected and then suddenly it disconnects, im now sure what part of the log file has the issue, meanwhile im copying some part of the file:
Jul 30, 2018 21:41:04.257 [2592] VERBOSE - We want 60 seconds ahead, last returned was 411.202000 and max is 485.735000.
Jul 30, 2018 21:41:04.257 [2592] VERBOSE - It took 0.0 sec to serialize a list with 0 elements.
Jul 30, 2018 21:41:04.257 [6016] DEBUG - Completed: [::ffff:127.0.0.1:61286] 206 PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) 2ms 342 bytes (range: bytes=0-)
Jul 30, 2018 21:41:04.758 [6016] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 30, 2018 21:41:04.759 [6016] VERBOSE - Auth: Came in with the master token, authorization succeeded.
Jul 30, 2018 21:41:04.759 [5020] DEBUG - Request: [::ffff:127.0.0.1:61287 (Loopback)] PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) Signed-in Token (rochoventura)
Jul 30, 2018 21:41:04.759 [5020] VERBOSE - * User-Agent => Lavf/58.9.100
Jul 30, 2018 21:41:04.759 [5020] VERBOSE - * Accept => /
Jul 30, 2018 21:41:04.759 [5020] VERBOSE - * Range => bytes=0-
Jul 30, 2018 21:41:04.759 [5020] VERBOSE - * Connection => close
Jul 30, 2018 21:41:04.759 [5020] VERBOSE - * Host => 127.0.0.1:32400
Jul 30, 2018 21:41:04.759 [5020] VERBOSE - * Icy-MetaData => 1
Jul 30, 2018 21:41:04.760 [5020] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 30, 2018 21:41:04.760 [5020] VERBOSE - * progress => 6.7
Jul 30, 2018 21:41:04.760 [5020] VERBOSE - * size => -22
Jul 30, 2018 21:41:04.760 [5020] VERBOSE - * remaining => -1
Jul 30, 2018 21:41:04.760 [5020] VERBOSE - We want 60 seconds ahead, last returned was 411.202000 and max is 485.735000.
Jul 30, 2018 21:41:04.760 [5020] VERBOSE - It took 0.0 sec to serialize a list with 0 elements.
Jul 30, 2018 21:41:04.761 [5136] DEBUG - Completed: [::ffff:127.0.0.1:61287] 206 PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) 1ms 342 bytes (range: bytes=0-)
Jul 30, 2018 21:41:05.264 [6016] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 30, 2018 21:41:05.264 [6016] VERBOSE - Auth: Came in with the master token, authorization succeeded.
Jul 30, 2018 21:41:05.264 [2592] DEBUG - Request: [::ffff:127.0.0.1:61288 (Loopback)] PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) Signed-in Token (rochoventura)
Jul 30, 2018 21:41:05.264 [2592] VERBOSE - * User-Agent => Lavf/58.9.100
Jul 30, 2018 21:41:05.265 [2592] VERBOSE - * Accept => /
Jul 30, 2018 21:41:05.265 [2592] VERBOSE - * Range => bytes=0-
Jul 30, 2018 21:41:05.265 [2592] VERBOSE - * Connection => close
Jul 30, 2018 21:41:05.265 [2592] VERBOSE - * Host => 127.0.0.1:32400
Jul 30, 2018 21:41:05.265 [2592] VERBOSE - * Icy-MetaData => 1
Jul 30, 2018 21:41:05.265 [2592] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 30, 2018 21:41:05.265 [2592] VERBOSE - * progress => 6.7
Jul 30, 2018 21:41:05.265 [2592] VERBOSE - * size => -22
Jul 30, 2018 21:41:05.265 [2592] VERBOSE - * remaining => -1
Jul 30, 2018 21:41:05.266 [2592] VERBOSE - We want 60 seconds ahead, last returned was 411.202000 and max is 485.735000.
Jul 30, 2018 21:41:05.266 [2592] VERBOSE - It took 0.0 sec to serialize a list with 0 elements.
Jul 30, 2018 21:41:05.266 [6016] DEBUG - Completed: [::ffff:127.0.0.1:61288] 206 PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) 2ms 342 bytes (range: bytes=0-)
Jul 30, 2018 21:41:05.588 [6016] VERBOSE - WebSocket: processed 1 frame(s)
Jul 30, 2018 21:41:05.771 [6016] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 30, 2018 21:41:05.771 [6016] VERBOSE - Auth: Came in with the master token, authorization succeeded.
Jul 30, 2018 21:41:05.772 [0540] DEBUG - Request: [::ffff:127.0.0.1:61289 (Loopback)] PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) Signed-in Token (rochoventura)
Jul 30, 2018 21:41:05.772 [0540] VERBOSE - * User-Agent => Lavf/58.9.100
Jul 30, 2018 21:41:05.772 [0540] VERBOSE - * Accept => /
Jul 30, 2018 21:41:05.772 [0540] VERBOSE - * Range => bytes=0-
Jul 30, 2018 21:41:05.772 [0540] VERBOSE - * Connection => close
Jul 30, 2018 21:41:05.772 [0540] VERBOSE - * Host => 127.0.0.1:32400
Jul 30, 2018 21:41:05.773 [0540] VERBOSE - * Icy-MetaData => 1
Jul 30, 2018 21:41:05.773 [0540] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 30, 2018 21:41:05.773 [0540] VERBOSE - * progress => 6.7
Jul 30, 2018 21:41:05.773 [0540] VERBOSE - * size => -22
Jul 30, 2018 21:41:05.773 [0540] VERBOSE - * remaining => -1
Jul 30, 2018 21:41:05.773 [0540] VERBOSE - We want 60 seconds ahead, last returned was 411.202000 and max is 485.735000.
Jul 30, 2018 21:41:05.774 [0540] VERBOSE - It took 0.0 sec to serialize a list with 0 elements.
Jul 30, 2018 21:41:05.774 [5136] DEBUG - Completed: [::ffff:127.0.0.1:61289] 206 PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) 2ms 342 bytes (range: bytes=0-)
Jul 30, 2018 21:41:06.275 [6016] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 30, 2018 21:41:06.276 [6016] VERBOSE - Auth: Came in with the master token, authorization succeeded.
Jul 30, 2018 21:41:06.277 [5020] DEBUG - Request: [::ffff:127.0.0.1:61290 (Loopback)] PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) Signed-in Token (rochoventura)
Jul 30, 2018 21:41:06.277 [5020] VERBOSE - * User-Agent => Lavf/58.9.100
Jul 30, 2018 21:41:06.277 [5020] VERBOSE - * Accept => /
Jul 30, 2018 21:41:06.278 [5020] VERBOSE - * Range => bytes=0-
Jul 30, 2018 21:41:06.278 [5020] VERBOSE - * Connection => close
Jul 30, 2018 21:41:06.278 [5020] VERBOSE - * Host => 127.0.0.1:32400
Jul 30, 2018 21:41:06.278 [5020] VERBOSE - * Icy-MetaData => 1
Jul 30, 2018 21:41:06.278 [5020] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 30, 2018 21:41:06.279 [5020] VERBOSE - * progress => 6.7
Jul 30, 2018 21:41:06.279 [5020] VERBOSE - * size => -22
Jul 30, 2018 21:41:06.279 [5020] VERBOSE - * remaining => -1
Jul 30, 2018 21:41:06.280 [5020] VERBOSE - We want 60 seconds ahead, last returned was 411.202000 and max is 485.735000.
Jul 30, 2018 21:41:06.280 [5020] VERBOSE - It took 0.0 sec to serialize a list with 0 elements.
Jul 30, 2018 21:41:06.280 [5136] DEBUG - Completed: [::ffff:127.0.0.1:61290] 206 PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) 4ms 342 bytes (range: bytes=0-)
Jul 30, 2018 21:41:06.786 [6016] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 30, 2018 21:41:06.786 [6016] VERBOSE - Auth: Came in with the master token, authorization succeeded.
Jul 30, 2018 21:41:06.787 [4120] DEBUG - Request: [::ffff:127.0.0.1:61291 (Loopback)] PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) Signed-in Token (rochoventura)
Jul 30, 2018 21:41:06.787 [4120] VERBOSE - * User-Agent => Lavf/58.9.100
Jul 30, 2018 21:41:06.787 [4120] VERBOSE - * Accept => /
Jul 30, 2018 21:41:06.787 [4120] VERBOSE - * Range => bytes=0-
Jul 30, 2018 21:41:06.787 [4120] VERBOSE - * Connection => close
Jul 30, 2018 21:41:06.788 [4120] VERBOSE - * Host => 127.0.0.1:32400
Jul 30, 2018 21:41:06.788 [4120] VERBOSE - * Icy-MetaData => 1
Jul 30, 2018 21:41:06.788 [4120] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 30, 2018 21:41:06.788 [4120] VERBOSE - * progress => 6.7
Jul 30, 2018 21:41:06.788 [4120] VERBOSE - * size => -22
Jul 30, 2018 21:41:06.788 [4120] VERBOSE - * remaining => -1
Jul 30, 2018 21:41:06.789 [4120] VERBOSE - We want 60 seconds ahead, last returned was 411.202000 and max is 485.735000.
Jul 30, 2018 21:41:06.789 [4120] VERBOSE - It took 0.0 sec to serialize a list with 0 elements.
Jul 30, 2018 21:41:06.789 [5136] DEBUG - Completed: [::ffff:127.0.0.1:61291] 206 PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) 3ms 342 bytes (range: bytes=0-)
Jul 30, 2018 21:41:07.295 [6016] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 30, 2018 21:41:07.295 [6016] VERBOSE - Auth: Came in with the master token, authorization succeeded.
Jul 30, 2018 21:41:07.295 [5020] DEBUG - Request: [::ffff:127.0.0.1:61292 (Loopback)] PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) Signed-in Token (rochoventura)
Jul 30, 2018 21:41:07.295 [5020] VERBOSE - * User-Agent => Lavf/58.9.100
Jul 30, 2018 21:41:07.295 [5020] VERBOSE - * Accept => /
Jul 30, 2018 21:41:07.295 [5020] VERBOSE - * Range => bytes=0-
Jul 30, 2018 21:41:07.295 [5020] VERBOSE - * Connection => close
Jul 30, 2018 21:41:07.295 [5020] VERBOSE - * Host => 127.0.0.1:32400
Jul 30, 2018 21:41:07.295 [5020] VERBOSE - * Icy-MetaData => 1
Jul 30, 2018 21:41:07.296 [5020] VERBOSE - * X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 30, 2018 21:41:07.296 [5020] VERBOSE - * progress => 6.7
Jul 30, 2018 21:41:07.296 [5020] VERBOSE - * size => -22
Jul 30, 2018 21:41:07.296 [5020] VERBOSE - * remaining => -1
Jul 30, 2018 21:41:07.296 [5020] VERBOSE - We want 60 seconds ahead, last returned was 411.202000 and max is 485.735000.
Jul 30, 2018 21:41:07.296 [5020] VERBOSE - It took 0.0 sec to serialize a list with 0 elements.
Jul 30, 2018 21:41:07.296 [5136] DEBUG - Completed: [::ffff:127.0.0.1:61292] 206 PUT /video/:/transcode/session/htlucf7edgdo5oc146n30a47/bd8db21f-d813-4358-ba06-807126d71cd4/progress?progress=6.7&size=-22&remaining=-1 (18 live) 1ms 342 bytes (range: bytes=0-)
